Will this setup Work
Tower Hobbies
Logged in as Guest
  Printable Version
Cell Indicator/Checker
Seller:  mds007
Details:   $11.00   |  7/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Will this setup Work
Page: [1]
Login
Will this setup Work - 5/19/2003 12:10:58 AM
DrDeath
Status: offline
I am building a flight box similar to those on the Ultimate flight box thread. I need both 12 and 24 volt connections. 12 going to a standard control panel and 24 going to a Dynatron starter. I was wondering if what I am thinking will work. See attachment. Two batteries daisy chained together for the 24 volt connection and then tie the control pannel off of one of the batteries. Seems like it should work. Any help would be greatly apprciated.
Click to see fullsize image.
Click for fullsize
       Post #: 1
Will this setup Work - 5/19/2003 1:23:30 AM
Rodney
Status: offline
Yes, will work fine.
(in reply to DrDeath)
       Post #: 2
Will this setup Work - 5/19/2003 1:59:58 AM
DrDeath
Status: offline
Thanks, after I build this box I will add it to the Ultimate Field box thread.
       Post #: 3
Will this setup Work - 5/19/2003 5:21:08 PM
z11355
Status: offline
that will work fine but you might want to
wire up swtich so that you can select
12v or 24v. The switch comes into play
because you can wire it such that you
get 12v @ 2x battery rating (like 2x 7AH -=14AH) OR 24v @ 1x battery rating.
       Post #: 4
Will this setup Work - 5/19/2003 8:41:10 PM
DrDeath
Status: offline
z
Can you draw a diagram of what you are saying? Not sure I fully understand what you are describing.
       Post #: 5
Will this setup Work - 5/19/2003 9:10:56 PM
nbcguy
Status: offline
Correct me if I'm wrong here, but when you hit the switch on the starter and close the circuit, won't both batteries then be connected in series and temporarily send 24v to the power panel? Just wondering...
_____________________________
If you ever drop your keys into a river of lava just let 'em go, because man, they're gone...
       Post #: 6
Will this setup Work - 5/20/2003 2:44:31 AM
theox
Status: offline
Wire the battery on the right hand side of your drawing
over to the one on the left, POS to POS and NEG to NEG.
Use a double pole double throw center off switch.
       Post #: 7
Will this setup Work - 5/20/2003 7:26:57 PM
z11355
Status: offline
actually, what we did was go in and
cut the traces on the circuit board
so that the 12v starter output jack
was floating and wired directly to the
12/24 switch. The rest of the power
panel was wired to a single 12v pack.
       Post #: 8
Will this setup Work - 5/21/2003 6:41:11 AM
Digitalflyer
Status: offline
Careful, it will work but the two batteries will be in different charge states and connecting two batteries like that in serial is not the best idea. It is best to keep serially connected batteries in a matched charge state.
-Amir
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.687RCU1
