digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
[QUOTE]Originally posted by blue62 i got this from the windsor propellor website (masterairscrew) maybe this will help with the propellor speed thing. just a thought For model airplane purposes, the best tip speed for efficiency and noise requirements is 600 feet per second. This is due to compressibility losses and the fact that subsonic airfoils do not work well in transonic/sonic speeds with required sound levels. Feet Per Second (ft/s) = RPM x diameter in inches x .00436 For example, to find the tip speed of a 10x6 on a .40 size engine running at 13,500 RPM, the equation would be 13,500 x 10 x .00436 = 588.6 ft/s. To find the correct diameter at 600 ft/s, use this formula: Diameter in inches = 138,000 / RPM Using a .40 engine running at 13,500 RPM, the equation would read as follows: 138,000/13,500 = 10.22 Rounding down, the correct diameter is 10" For both of the above formulas, use RPM for the optimum power band of your engine. Consult your owner's manual if you do not know this number. john [/QUOTE] nice formula but since the turboprop we use (Wren) has no limit on the speed you cant use this formula our formula is: buy lots of props mount them and see wich one performs best all is also dependant on weather , model ,weight,etc
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy. "Home of the Jet-1A Gears"
