digitech
Joined: 8/23/2004 From: klimmenlimburg, NETHERLANDS Status: offline
quote:
ORIGINAL: mec price for the pitch prop: please send an email to pj-w@aon.at there are two things to mention: # have you thought of the fact, that the pitch prop will need a completely different ECU (cause of the accurate rev alterations)? # the revs that you are going on your unit will probably make explode the pitch prop unit. so you will be something like a pioneer or developer! your pilatus project is impressive, wow! mec hi mec ok i got a reply eather they dont want to sell me one witch i think they do or it just wont hold the hp,s from the wren read this: ----- Original Message ----- From: Digitech Electronics To: pj-w@aon.at Sent: Monday, June 14, 2004 10:48 AM Subject: pitch prop Hi i would like to know how much are you charging for this unit? (pitch prop) I have got a wren engine it has a shaft of 6mm so it can fit now any prop The max torque is about at 6500-7000 rpm on the shaft It is for a pilatus pc-6 spinner would be 90-95mm Props I use vary from 22x10 up to 26x10 The best performance I have at 22x12 mentz prop 8000 rpm,s Best Regards, Sandor Kruise Digitech Electronics B.V Oliemolenstraat 5 6343PW Klimmen Netherlands Tel:+31454059000 Fax+31454059001 www.digitech.nl sales@digitech.nl Bank:Rabobank account:125915896 Swift:RABONL2U Iban:NL73RABO0125915896 the reply: Van: RD technotrade Gmbh [mailto:aon.912585643@aon.at] Verzonden: maandag 14 juni 2004 11:21 Aan: Digitech Electronics Onderwerp: Re: pitch prop Hello, sorry our prop-unit is only with an PJ-W-R or Limited Edition Turbine obtainable. Because it is made for this engine. Best regards René Dusl --------------------------------- typical answer from a engineer,s point of view but not buisiness to bad .............
_____________________________
Sandor Kruise Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy. "Home of the Jet-1A Gears"
