Caaine
Joined: 7/1/2008 From: Reykjavík, ICELAND Status: offline
I think you are on the right track, according to a stickie post on this forum regarding gearing. I myself have a e-Firestorm and been thinking similarly so I ran the numbers (if I understood the method correctly) based on a Firestorm. Being under the sweet spot but as close as possible would be done with a stock spur and 31t pinion (-0,0388) but being right on spot would be done using 93t spur and 35t pinion which results in 0,002933, which is positive number but damn close to zero (which as I understand is the goal here). If we use that as basis (93/35) and try to work out theoratical max speed, according to my calculations, it would reach 54 mph. While the stock spur and pinion would only get you 31,32 mph using the same motor. I´m not 100% on these things but according to this post ( Understanding Gear Selections ) being on the "sweet spot" would result in LESS heat (i.e. not overgeared). Increasing the pinion would then get you closer to the sweet spot, yet you experience more heat being generated. Since my knowledge is pretty much based on the previously mentioned post on these things I cannot understand why that would happen.
