Ryan Smith -> RE: Post all your "crappola" here (12/1/2008 6:39 PM)
quote:
ORIGINAL: jrpav1 Better to check it and find nothing than NOT check it and have a problem. Think of a YS as a flying Harley (an old one - not an Evo or a Twinkie). If you can keep one of them happy, you'll be fine with a YS. :) So Joe, are you going to the Dark Side now too? Cool. At least I won't be the only one in D1 with an oil dripping vibrator on the nose of my airplane! LOL John Pavlick Team Black Magic, Tech-Aero Designs I've always thought that the two-strokes were a lot messier than my YS's. Last year before the Nats was when I was still flying the OS 1.40 on an Asano pipe and my buddy had a Brio with a 1.60DZ on a Hatori short pipe. It was a dry summer, and we were flying from a newer field that had more dirt than grass. Joey would wipe dry dust off of the bottom of his airplane, and inside his chin cowl, whereas I would be wiping mud off of the bottom of my airplane after every flight. If you get them setup right, you may have a slight bit of fuel spit out of the carb, but even that's preventable with a velocity stack. If one of those motors leaks, then there's something wrong with it. They also don't vibrate that bad if you run the right fuel in it. I've not owned a 1.70, so most of my experience is with the 1.60DZs, the 1.40DZs, Ls, and the FZ series. The 1.60DZ has to be the best engine I have ever owned, and from the 1.70 that I broke in for a friend in an airplane I built for him, it seemed to be a cherry of a motor right out of the box. I'll admit that I'm a moron when it comes to motors, but I had more trouble with the OS's than I have with YS and the YS's have more parts. Not saying that the OS's are junk, I just prefer the YS. Different strokes for different folks, I guess.
