RE: Post all your "crappola" here (Full Version)
All Forums >> [RC Airplanes] >> Pattern Flying
Message
Ryan Smith -> RE: Post all your "crappola" here (12/6/2008 11:24 PM)
Joe,
I'm going to Li-po's; dual TP 730's going to a Tech Aero regulator, for redundancy. I have been running Fromeco 2600 Relions, which are Li-ion packs with great success, but I want to try something new. I'm pretty sure that the Li-po's have a little higher 'C' rating than do the Li-ions, meaning that they have a little more punch. Both have been used sucessfully, so pick whichever you feel more comfortable with. If you go Li=po, you may want to charge outside your airplane, in case there are issues with charging, however I haven't seen any issues with the smaller batteries, and with the chargers today, you have to be really trying to burn something up to get the pack to go.
Here's a Wikipedia article detailing the differences.
http://en.wikipedia.org/wiki/Lithium-ion_polymer_battery
gaRCfield -> RE: Post all your "crappola" here (12/6/2008 11:56 PM)
Doesn't seem to be a huge difference; maybe the Li-ion is a safer bet for a first lithium battery? I think with a 1.20 plane and the (lower end digital) servos I have, I shouldn't need much more than a 5amp (2-3C) draw. The Li-ion is smaller, lighter, and has more capacity.
Props to Tech-Aero.net for regulators; I will be using them as well[;)]
Thanks Ryan!
jrpav1 -> RE: Post all your "crappola" here (12/7/2008 12:43 AM)
Ryan,
I have exactly that same setup in my Black Magic V2.2: 2 Tech-Aero regulators with 2 TP 730 LiPO's. No problems in a full season of flying. The reason this works so well is because you can adjust the output voltage of the regulators within a fine degree. Our normal configuration gives you about 30 millivolts of resolution. When you start flying with the dual regulator setup, use a charger that shows you how much energy went back into the batteries. You may find that one battery always requires slightly more - obviously this one has been delivering more energy to your system. To balance things out, adjust the voltage on this regulator one step lower and fly some more. Eventually you'll find that both batteries require nearly the same amount of energy when re-charging. That's your goal. Even if you don't do this you have the added security of an "extra" battery and regulator - if either one fails you can still fly!
John Pavlick
Team Black Magic, Tech-Aero Designs
gaRCfield -> RE: Post all your "crappola" here (12/7/2008 4:06 AM)
Does anyone have experience with Central Hobbies Lipos?
I thought I had a lot of crappola, but now looking back I guess I gotta push a little harder[:'(]
rcpattern -> RE: Post all your "crappola" here (12/7/2008 8:27 PM)
The NHP batteries from Central work well. Also get the charger that goes with them. Just make sure you charge them adequately before you fly (long story)....
Arch
gaRCfield -> RE: Post all your "crappola" here (12/7/2008 8:31 PM)
I'm assuming the charger I've got should be fine - charges and balances lipos...
But thanks, the batteries are on my list.
rcpattern -> RE: Post all your "crappola" here (12/7/2008 9:07 PM)
The NHP charger is cheap and works really well with those packs. I prefer to use it with those packs.
gaRCfield -> RE: Post all your "crappola" here (12/11/2008 2:09 PM)
I just balanced two APC props last night; each one required an entire blade (back side) to be covered in clear nail polish, dry, and then more applied to the tips - they were both pretty far out of balance.
What do you guys think of Zinger wooden props? Blades are a little narrower than APC, but the prop is much lighter and the ones I have require very little to balance. They're also progressively pitched, from 6" to 10" (which a chart says is equivalent to an 8" pitch)
J Lachowski -> RE: Post all your "crappola" here (12/11/2008 4:29 PM)
quote:
ORIGINAL: gaRCfield
Zingers. Inefficient design. Will break on prop strike.
rcpattern -> RE: Post all your "crappola" here (12/11/2008 5:22 PM)
Stay with APC...they are definitely some of the most efficient props out there. The Zingers are older props and definitely not useful for todays pattern applications,
Arch
gaRCfield -> RE: Post all your "crappola" here (12/11/2008 9:38 PM)
Ok, thanks!
patternflyer1 -> RE: Post all your "crappola" here (12/12/2008 2:40 AM)
I lost a plane due to a new NMP li-ion 2 years ago. Charged fully the night before with the NMP charger, checked under load before I flew, first flight of the day. Took off fine and then it was gone. 1 cell checked in at 0, the other was fine. Not sure why it went bad. It had about 10 flights on it. Lipo's, never had a problem so far. Well, except for when I flew 8 1/2 flights on a 730.. If I had only stopped at 8.. lol[:D]
Chris
gaRCfield -> RE: Post all your "crappola" here (12/12/2008 4:26 PM)
Hmm, makes sense. Thanks.
gaRCfield -> RE: Post all your "crappola" here (12/13/2008 9:55 PM)
Has anyone had problems with regulators malfunctioning? Do most of you guys use regs?
gaRCfield -> RE: Post all your "crappola" here (12/20/2008 7:02 AM)
How does one repair wing tube sleeves that are installed in a wing? The ones on my plane seem to crack/split really easily.
BERUSTY -> RE: Post all your "crappola" here (12/22/2008 6:19 PM)
Old School Pattern Prop $4.50
BlackBerry PDA $490.00]
Reaching 100,000 + with 23 lives...Priceless
Santa is coming very soon,
Rusty Dose
Team Futaba
Team YS Parts and Service
The same game pictured above is now over 302,000 with 40 lives...shooting for 1,000,000
cdodom -> RE: Post all your "crappola" here (12/24/2008 5:07 AM)
that game is really that addicting. prob the best app for a blackberry.
Chris Odom
gaRCfield -> RE: Post all your "crappola" here (12/24/2008 12:54 PM)
Happy Holidays everyone!
gaRCfield -> RE: Post all your "crappola" here (1/2/2009 8:37 PM)
Will hard-mounting a YS 110 to my Yak really shorten the life of my servos? Is a soft mount a 'must have' for YS engines?
apereira -> RE: Post all your "crappola" here (1/2/2009 8:57 PM)
I had my Ys110 hard mounted and never had problems at all, it does not vibrate that bad.
rgreen24 -> RE: Post all your "crappola" here (1/2/2009 9:02 PM)
Rusty you need to get a life. lol. My daughter and i go back and forth trading high scores. she now has 7730, to my 6630. How in the hell did you get 23 lives?[:D]
gaRCfield -> RE: Post all your "crappola" here (1/2/2009 9:03 PM)
quote:
ORIGINAL: rgreen24
let me guess: "up, up, down, down, left, right, left, right, B, A"? [:D]
rgreen24 -> RE: Post all your "crappola" here (1/3/2009 3:54 AM)
you forget select , select start. best codes ever for the Nintendo game Contra
gaRCfield -> RE: Post all your "crappola" here (1/8/2009 8:11 PM)
I ordered my first YS today (FZ110-s) [:D][:D][:D][:D][:D]
cdodom -> RE: Post all your "crappola" here (1/8/2009 8:53 PM)
I promise you It wont be your last. Wait till you get the 170DZ
Chris Odom
Team Black Magic
Team Dragon Fire
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Valid CSS!
SITE MAP!   : :   FORUM RULES
1.328125
