MDS 15 diesel for real???
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> MDS 15 diesel for real??? Page: [1]
Login
MDS 15 diesel for real??? - 8/16/2008 3:43 PM
AMB
Score: 100
Last Login: 11/7/2009
Status: offline
Just was on the glow site and a chap asked what happened to MDS the do have a site in Europe just bring up in Goggle a Vari compression .15 is listed at 59 Euros
that is a surprise martin
they say a 6x3 or 6x4 no muffler sounds like a wimp for a 15 (maybe a typo on prop size??)
After fishing a round the site (MDS) I found a pix it is a 4 bolt head with an allen screw for compression adjustment needle in cast carb body thus c/l looks like a bolt thru nuffler most
likely the Glow muffler will fit. I would guess you would plug the holes for the needle valve anf fit an rc caaR, Odd they do not offer in RC version
Any of you guys in Europe familiar with this engine??
< Message edited by AMB -- 8/16/2008 4:33 PM >
Hide Signatures
       Post #: 1
RE: MDS 15 diesel for real??? - 8/16/2008 6:29 PM
Patxipt
Score: 100
Status: online
Here's the webpage for that little baby
http://mds-engines.com/catalog/avia-01500.200
Catalog here
http://mds-engines.com/files/Katalog_Engl.pdf
These engines are indeed sold at €59. Over we we can get the pylon engine 15FS with pipe and rear exhaust for €46!
From what I am able to discern in their catalog, the engine is the same as the 15F with a diesel head. The carb from the rc version, 15FS is surely bolt-on, as is the silencer All these .15 engines seem to be plain bearing.
As for the prop range, they are using the same ones as for the glow versions, which are high-speed glows, hence the low prop width.
Postage costs should be peanuts, according to the website of the postal service they use!
Hmmmmmmmmm, very tempting indeed
Edit: added catalogue url
< Message edited by Patxipt -- 8/16/2008 6:31 PM >
_____________________________
Club Saito member #632
Once you hear the sound of a multicylinder 4-stroke, you''ll be hooked forever!
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: MDS 15 diesel for real??? - 8/16/2008 9:03 PM
Lou Crane
Score: 100
Last Login: 11/4/2009
Status: offline
Francisco and AMB,
The first listing page allows you to pop up the specs in more detail, by clicking the small print box bottom left...
One of the two urls lists power output, which if I recall right, claims .31 horsepower (DIN or SAE?) at 14K, for the "vari-comp" - can't they say diesel? - and .36 for the shrieking glow version at 19K.
Comparison of pictures for these two look like they left the stopper in the sink for the "VC" (DIESEL! D***IT!) ...
Interesting, Thanks!
(edits - clumsy wording...)
< Message edited by Lou Crane -- 8/16/2008 9:04 PM >
\BEST\LOU
Lou Crane, Sierra Vista, AZ
Hide Signatures
(in reply to Patxipt)
       Post #: 3
RE: MDS 15 diesel for real??? - 8/17/2008 3:09 AM
AMB
Score: 100
Status: offline
59 Euros about $126 US figure $20 for a carb $15 for a muffler thus $161 right up there with Enya and I did notice on the Modelflight site today the Enya 4 strk diesel no longer available the Enya 15 now $170 and it is a BB . Think its worth he extra $10 martin
unless i am mistaken the Enya I think was around $125 a month ago
< Message edited by AMB -- 8/17/2008 3:11 AM >
Hide Signatures
(in reply to Lou Crane)
       Post #: 4
RE: MDS 15 diesel for real??? - 8/17/2008 5:16 AM
Motorboy
Score: 105
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: Lou Crane
.... for the "vari-comp" - can't they say diesel? ...
No, the russian people does not to say "Model diesel engine", the engine in russian are called for "Kompressionovye dvigatel´" (Компрессионовые двигатель), it means compression (ignition) engine because the engine has the contrapiston who are variable and will be called for "compression ignition engine".
Jens Eirik
Carpe diem quam minimum credula postero
Hide Signatures
       Post #: 5
RE: MDS 15 diesel for real??? - 8/17/2008 11:33 AM
Mr Cox
Score: 100
Status: offline
Maybe I've missed something but 59 Euros shouldn't be more than about 87 US dollars...
But you would have to add for shipping.
Hide Signatures
(in reply to AMB)
       Post #: 6
RE: MDS 15 diesel for real??? - 8/17/2008 12:40 PM
AMB
Score: 100
Status: offline
Mr cox== right you are. I read the exchange\rate wrong on the conversion martin
You chaps on that side of the pond is it a BB or bushed engine??
Patixpt you can most likely answer this one
< Message edited by AMB -- 8/17/2008 12:50 PM >
Hide Signatures
(in reply to Mr Cox)
       Post #: 7
RE: MDS 15 diesel for real??? - 8/17/2008 1:23 PM
gkamysz
Score: 105
Status: offline
From the pictures it looks like a bushing engine. I've seen these on Ebay. They looked like current production, but I hadn't seen them prior to that. The specs aren't outstanding but it is a bushing engine. Who's going to be brave enough to send their credit card info to Eastern Europe?
Greg
Hide Signatures
(in reply to AMB)
       Post #: 8
RE: MDS 15 diesel for real??? - 8/17/2008 1:54 PM
AMB
Score: 100
Status: offline
Greg not me won't the chance ,too bad they do not take Pay Pal which I use use for things like this I keep a low $ balance in this one martin
Hide Signatures
(in reply to gkamysz)
       Post #: 9
RE: MDS 15 diesel for real??? - 8/17/2008 5:01 PM
slope-soarer
Score: 100
Last Login: 8/29/2009
Status: offline
I haven't seen any comments, or details on the MDS diesel.
Over here in the U.K MDS gained the reputation........ MDS... Metal Door Stop.
Some swore by them as they were very cheap, others swore at them for days on end when they would never run correctly. For a glow engine they were very cheap, and there were even some people who got one that worked, or so they reckoned.
I remember someone smashed one to pieces with a BIG hammer and posted photos of the dead engine, his patience was finally exhausted and he reckoned to save his sanity by killing the damned thing !
MDS diesels may well work.... strange things do happen !
Reg
Hide Signatures
(in reply to AMB)
       Post #: 10
RE: MDS 15 diesel for real??? - 8/17/2008 5:31 PM
AMB
Score: 100
Status: offline
Looks like the winners are Davis, PAW, Enya "the diesel Olympics" martin
Hide Signatures
(in reply to slope-soarer)
       Post #: 11
RE: MDS 15 diesel for real??? - 8/18/2008 12:24 AM
Patxipt
Score: 100
Status: online
I don't feel like giving my MC number to them too, PP comes in handy for these situations. Now I've lost the kick to buy one of these
I was feeling like buying the MDS 15 with tuned pipe I mentioned around 1 or 2 years ago, but heard that brick story about these engines
I bought my CL PAW09BR for €70 last year, although NOS from the LHS. For the same €59 I can get a Davis head for my 40LA and still buy a quarter liter of castor and 1 liter of kero for the fuel and be certain that it will run! (I need to feel brave about doing this conversion soon... )
< Message edited by Patxipt -- 8/18/2008 12:27 AM >
Hide Signatures
(in reply to AMB)
       Post #: 12
RE: MDS 15 diesel for real??? - 8/21/2008 11:29 AM
Dumuk
Score: 100
Last Login: 10/31/2008
Status: offline
Greetings. I am looking through some forums about modeling and I would like to ask slope-soarer just one question. You have written so many and so beautifully ( ) about MDS "crap" products (from your words), but only one question - personally you had experience with MDS engines? Not your neighbor/friend/grandmother, but personally you? Or you just "heard somewhere", "read somewhere"?
P.S. I can only spare "someone", who tried to repair engine with a "big hammer" instead of sending to the competent repairmen...
P.P.S. people may think independently... "strange things do happen !".
< Message edited by Dumuk -- 8/21/2008 11:57 AM >
Hide Signatures
       Post #: 13
RE: MDS 15 diesel for real??? - 8/21/2008 1:59 PM
Hobbsy
Score: 117
Status: offline
Dumuk, I'm one of the guys who has good luck with MDS engines, I own about 12 of them, with two being converted to Diesel. The problem most people had was trying to run them on high nitro, they simply won't run on more than 5%, Fox engines are the same. The .78 for example ran great when you treated it like it was a .91 and ran a 14x6 on it. As a Diesel the .78 turns a 12x8 three blade at just under 9,900. The 1.48 converted to Diesel turns a 14x7 three blade at just under 9,000. The 1.48 is actually a 1.506.
< Message edited by Hobbsy -- 8/21/2008 2:01 PM >
If it ain''t a Farmall, it ain''t at all.
Hide Signatures
(in reply to Dumuk)
       Post #: 14
RE: MDS 15 diesel for real??? - 8/22/2008 12:28 PM
locktite401
Score: 100
Status: offline
quote:
ORIGINAL: AMB
This MDS looks like a nice little beginners engine for competition control line. The "allen screw" is actually a push pull head. The bulge on the bypass indicates schnurle porting and the claimed output of about 0.31BHP is equivalent to a bit less than a good stock Oliver Tiger diesel.
Not a wimpy little engine at all. Is probably superior to a CS Oliver Tiger.
The 6x3 - 6x4 isn't a cox style .049 prop but probably a relatively wide blade European F2D combat prop. The motor might be meant for some eastern european beginner c/l combat class.
Probably wouldn't convert to r/c very well at all. Why don't you buy a PAW instead.
< Message edited by locktite401 -- 8/22/2008 12:31 PM >
Hide Signatures
(in reply to AMB)
       Post #: 15
RE: MDS 15 diesel for real??? - 8/25/2008 4:47 PM
slope-soarer
Score: 100
Status: offline
quote:
ORIGINAL: Dumuk
Hi,
I could quote my own experiences, but would they be necessarily true ? I might just be biased against MDS engines. I DO like O.S, T.T, MVVS and PAW and that's for sure.
A quick search of the newsgroups associated with RC will provide any amount of comments about MDS engines. A lot of unfavourable comments and some favourable ones. There is a very broad range of satisfied/dissatisfied users comments, the balance is more dissatisfied.
There is sufficient reading to make my comments appear to be valid !
The main problem seemed to be around quality control. The MDS could be a good runner and did have plenty of power, however there were carb issues and other problems. If you got a runner it was a good cheap engine, alternatively you could get one that would never run right and was unreliable.
The main plus point for MDS was low price... for just a bit more money an engine with more consistent quality could be bought.
The guy who posted photos of the MDS engine he "killed" with a big hammer did so because he was thoroughly dissatisfied with it, why send a cheap engine in for repair when it was probably going to come back with the same problems ?
PAW diesels are easy starters, run well, attract favourable comments, have easily available spares and there are other diesels with similar attributes.
MDS have a shaky reputation, spares MAY be available, most retailers here no longer sell MDS glow engines. The MDS diesel may suffer the same fate and not be sold by major retailers for long.... who knows ?
Reg
Hide Signatures
(in reply to Dumuk)
       Post #: 16
RE: MDS 15 diesel for real??? - 10/9/2008 7:17 PM
merugo
Score: 100
Last Login: 5/23/2009
Status: offline
pls, have a look at this
http://www.rus-sell.com/toys%2C+hobbies/engines+for+rc+models/catalog1236.html
Hide Signatures
       Post #: 17
RE: MDS 15 diesel for real??? - 10/21/2008 9:58 AM
Philip R
Score: 100
Last Login: 12/22/2008
Status: offline
It was me...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to merugo)
       Post #: 18
RE: MDS 15 diesel for real??? - 10/21/2008 6:52 PM
gcb
Score: 100
Status: offline
quote:
ORIGINAL: Philip R
It was me...
Gee Philip, I've never seen someone admit that they couldn't fix something with that much frustration (or anger). I'm sure many of us have wanted to...but you actually did it. Cool!
...Shall we call that a Thor modification?
George
Hide Signatures
(in reply to Philip R)
       Post #: 19
RE: MDS 15 diesel for real??? - 10/22/2008 11:49 AM
AMB
Score: 100
Status: offline
NOT TAKING A CHANCE ON THIS ONE
Dar Zeelon is sending me a MMVS 15 RC carb and muffler (diesel) martin
Sill a lot less than the Enya 15
< Message edited by AMB -- 10/22/2008 8:56 PM >
Hide Signatures
(in reply to AMB)
       Post #: 20
RE: MDS 15 diesel for real??? - 10/31/2008 11:58 PM
Dumuk
Score: 100
Status: offline
For how long your psychotherapist didn't seen you?
Hide Signatures
(in reply to AMB)
       Post #: 21
RE: MDS 15 diesel for real??? - 11/1/2008 12:30 PM
Asakivi
Score: 100
Last Login: 5/12/2009
Status: offline
MDS uses ball bearing in all engines instead of plain bearing!!!
Hide Signatures
       Post #: 22
RE: MDS 15 diesel for real??? - 11/1/2008 1:34 PM
Hobbsy
Score: 117
Status: offline
One thing nobody mentioned was that Diesels do not have the quitting issues that glow engines have. A Diesel can be set up really poorly and still continue to run. And, for the guy who used the hammer, I'd get kicked off this site for saying what I really think, But, there is no such thing as a bad engine. They're all made out of the same stuff, have the same adjustments and each has its fuel, prop and glow plug requirements.
Hide Signatures
(in reply to Asakivi)
       Post #: 23
RE: MDS 15 diesel for real??? - 6/25/2009 7:11 AM
fiery
Score: 100
Status: offline
MDS 15D
Anyone tried one of these yet?
Hide Signatures
(in reply to Hobbsy)
       Post #: 24
RE: MDS 15 diesel for real??? - 6/26/2009 12:15 AM
AMB
Score: 100
Status: offline
OK guys how about the K.I.S.S, principal MDS was never noted as good quality engine varied from batch to batch if you were lucky you would get a good runner,as far as 15s go
Pe Reivers may have a few MVVS 15Ds left or really keep it simple and get an OS15 LA easy to get and put a Davis head on it martin
some of the UK sellers may have some EnyaCX15d ??? Model Flight down under does not
The OS LA conversion is the easiest way to go
jUST LOOKED AT THE GLOW SITE AND A CHAP WAS ASKING ABOUT MDS SEVERAL REPLIES STATED POOR QC
< Message edited by AMB -- 6/26/2009 1:38 AM >
Hide Signatures
(in reply to fiery)
       Post #: 25
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.656RCU1
