DCoy70 -> RE: nitro planes SU-26 50CC specs (11/28/2008 2:47 PM)
Weel. I was able to get longer bolts and cut them to size, the pants are on now. Bobzilla, when you put in the engine, what was your vertical offset, Im gonna make some wood dowels 4" and see how that goes, worried about my drill press since is only a 3 inch. Here in Miami is a pain to find hex bolts also in the 4 to 5 inch range. I also saw in your gas tank setup and on the kit, that the wing bolts are right by the wing tube, are you having a hard time putting in the wing bolts since you moved your tank setup? Note: I always take the batteries out of the plane after I fly them, so putting in the batteries on the motor box would not allow me to do this. I was hoping with this RCGF 62cc I would be able to put the batteries inside the fuse, maybe right behind the throtle and choke servos, and the ignition battery between the two servos. Also, what spinner size did you get, I have only a drill guide for DA50, and dont know if the holes would match up, I need to see if Piston knows if they do, will give him a call.
