Best glow driver?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> Best glow driver?
Page: [1] 2   next >   >>
Login
Best glow driver? - 8/20/2008 2:57 PM
Jon Wold
Score: 105
Last Login: 5/8/2013
Status: offline
Here's mine: It's a non-knocking plug heater made in Norway, check it out:
http://jonwold.blogspot.com/2008/08/auto-4c-glow-pro.html
Disclaimer: As you can tell from my blog post I know the guy who makes it but I have no economic incentive for posting this. I think it's a fantastic glow driver that will save plugs, engines and keep starting the 4-stroke beasts safe for everyone.
I post it here so that we can discuss glow drivers (I know there are more out there including Rcats from Central hobbies) and get feedback. What do you think of this glow driver?
Click to see fullsize image.
Click for fullsize
_____________________________
F3A blog: http://www.aerowold.com
Hide Signatures
       Post #: 1
RE: Best glow driver? - 8/20/2008 3:21 PM
Red B.
Score: 113
Last Login: 5/14/2013
Status: offline
It seems to be a nice piece of equipment! One question though:
Is it a true glow driver in the sense that it regulates the glow-plug current to compensate for varying electrical resistance of the glow plug, i.e., does the glow driver automatically increase the current when the glow plug is cooled by fuel droplets, or is it a constant current source?
/Red B.
Hide Signatures
(in reply to Jon Wold)
       Post #: 2
RE: Best glow driver? - 8/20/2008 3:43 PM
Jon Wold
Score: 105
Status: offline
Yes (or should I say Ja).
Here's a snippet from the manual:
"The plug power is continuously regulated to the preset power with regards to the battery voltage. Glow-Pro also measures the plug temperature and automatically adjusts the plug power to keep the temperature to the preset level. This makes the Glow-Pro uncritical to both sinking battery voltage and “drowned” glow plugs."
Hide Signatures
(in reply to Red B.)
       Post #: 3
RE: Best glow driver? - 8/20/2008 6:44 PM
fancman
Score: 100
Last Login: 11/26/2012
Status: offline
Looks expensive. Why would you need one of these compared to a plain old glow starter? I'm curious. Thanks
< Message edited by fancman -- 8/20/2008 6:45 PM >
Hide Signatures
       Post #: 4
RE: Best glow driver? - 8/20/2008 7:31 PM
AAbdu
Score: 102
Last Login: 7/23/2012
Status: offline
I am in rthe market for a glow driver now, what is the price and availability?
Anthony
Hide Signatures
(in reply to fancman)
       Post #: 5
RE: Best glow driver? - 8/20/2008 8:33 PM
Nathan King
Score: 108
Last Login: 10/9/2011
Status: offline
Call me crazy, but I just use an inexpensive starter from the hobby shop.
AMA 861014 | NSRCA 4460
Class 402 Intermediate | District 5
Hide Signatures
(in reply to AAbdu)
       Post #: 6
RE: Best glow driver? - 8/20/2008 8:55 PM
tggilkey
Score: 100
Last Login: 5/17/2013
Status: offline
Until the advent of the YS DZ's there didn't seem to be much of a need for a delay glow driver, but I can tell you from personal experience that the delay feature is worth every penny. Prior to using one I had everything from happen from props loosening, to spinner cones wrinkled, to threads messed up on the crank/jam nuts, to the spinner back plate and thrust washer grinding themselves into little pieces of aluminum. The knock on initial ignition, even if it results in a successful start, can't be good for the crank pin, either end of the connecting rod, or the piston (to say nothing about the stress that initial whack can put on the front end of the plane even with a soft mount). I have heard about, but never seen, engine cowls being damaged by that kick. With a delay, most starts are extremely smooth; sometimes so smooth with the idle throttle matching what the starter is turning, only the change in sound will signify the engine is really running on its own. The one I have (similar to the one in discussion here) has adjustable delay timing as well as plug current. It was worth the cost. With a second person to punch a button, an option could be to have the other person fire up the glow plug once the engine is turning. Many times I'm flying by myself so the delay driver is great. Based on my experience and comments of others who use something like it, I would recommend using one.
My 2 cents worth.
Tom
Hide Signatures
(in reply to Nathan King)
       Post #: 7
RE: Best glow driver? - 8/20/2008 8:59 PM
rcpattern
Score: 100
Last Login: 5/19/2013
Status: offline
The RCATS driver is really nice. It is still around 100USD but the delay drivers with the DZ's make life a lot easier. Not 100% necessary, as there are other ways, but I think it is much easier using the time delay drivers for the DZ's.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to tggilkey)
       Post #: 8
RE: Best glow driver? - 8/20/2008 9:03 PM
wild 330
Score: 100
Last Login: 8/15/2012
Status: offline
RCATS also has the option of a delay glowdriver, 5 seconds delay.
Hide Signatures
(in reply to rcpattern)
       Post #: 9
RE: Best glow driver? - 8/20/2008 9:36 PM
Jon Wold
Score: 105
Status: offline
As Red B. from Sweden was asking, this (and some other glow drivers that are in the upper price range) provide a variable current to the plug so that the plug heat remains the same regardless of amount temperature, raw plug full of fuel etc. If you use a normal glow clip w/battery it's gonna start glowing immideately when its connected. That's not good for the plug, and you get the problem of backfiring. With these new generation of non-knocking heaters you can start spinning the engine before it starts giving current to the plug, eliminating the backfiring problem.
The driver I use is 1295,- NOK which is equivalent to 240 USD. It sounds expensive but the currency rate is very much in favour of NOK right now. A few years ago it would have been a $100 less but yes it is not cheap.
Hide Signatures
(in reply to wild 330)
       Post #: 10
RE: Best glow driver? - 8/20/2008 9:41 PM
Rune
Score: 100
Status: offline
I have one off the from Norway....works great .
I cost a bit more than the one from (i really dont know from where) JApan??
but i had to change the battery in the other one ......
Rune Gjelsnes
email: rungjels@gmail.com
Hide Signatures
       Post #: 11
RE: Best glow driver? - 8/20/2008 9:43 PM
fancman
Score: 100
Status: offline
quote:
ORIGINAL: Jon Wold
$240.00!!!!!! I've been flying glow engines for 30 yrs and I've never heard of or needed a delay glow driver. Glad I didn't at that price.
Hide Signatures
       Post #: 12
RE: Best glow driver? - 8/20/2008 9:47 PM
Jon Wold
Score: 105
Status: offline
It's sorta like sliced bread - once you get used to it there's no going back.
Hide Signatures
       Post #: 13
RE: Best glow driver? - 8/20/2008 10:12 PM
Rune
Score: 100
Status: offline
then you most likely havent used a YS DZ many flights .....dont try to be mean .
< Message edited by Rune -- 8/20/2008 10:13 PM >
Rune Gjelsnes
Hide Signatures
       Post #: 14
RE: Best glow driver? - 8/20/2008 10:32 PM
rcpattern
Score: 100
Status: offline
Have to agree with Rune on this one. I don't think you need to spend 240 for a driver either. There are others that work. However, if you arent using a delay driver and you get the dreaded DZ kick and it breaks the front of your 2500 pattern airframe. The 100 or so, or even the 240 seems cheap then. I personally use the NHP driver from Japan, and love it. There are other techniques that will work, however, the delay drivers definitely low this risk.
Arch
Hide Signatures
(in reply to Rune)
       Post #: 15
RE: Best glow driver? - 8/20/2008 10:52 PM
alex24
Score: 100
Status: offline
You may also consider
Sullivan Onboard Glow Driver!!
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=M060
http://www.sullivanproducts.com/
Alex
Hide Signatures
       Post #: 16
RE: Best glow driver? - 8/20/2008 11:24 PM
fancman
Score: 100
Status: offline
quote:
ORIGINAL: Rune
I get it. I knew the YS DZ engines were expensive but didn't know about the starting issues. You're right. I haven't used a YS and it's to late for this old dog to learn that trick.
< Message edited by fancman -- 8/20/2008 11:25 PM >
Hide Signatures
(in reply to Rune)
       Post #: 17
RE: Best glow driver? - 8/20/2008 11:28 PM
Rune
Score: 100
Status: offline
try them and you love them..the YS......
in this hobby noone is to old!
Rune Gjelsnes
Hide Signatures
       Post #: 18
RE: Best glow driver? - 8/20/2008 11:34 PM
fancman
Score: 100
Status: offline
Naaaaaaaaa I think I'm going to stay in the cheap seats with my OS 160. Tons of power, easy starts and $15.00 glow driver.
Hide Signatures
(in reply to Rune)
       Post #: 19
RE: Best glow driver? - 8/21/2008 1:29 AM
Gulliver
Score: 100
Status: offline
Its not going to win over any clip starter fans, but the Radio South Pro Driver does everything the R-cats driver does for about $80. (Uses NiMh instead of Lipo.)
http://www.radiosouthrc.com/thumbnail.asp?cid=17
Hide Signatures
       Post #: 20
RE: Best glow driver? - 8/21/2008 2:15 AM
Mastertech
Score: 108
Last Login: 5/20/2013
Status: online
The Radio South drivers do not have a soft start, yet.
Be a kid forever, fly models.
Hide Signatures
(in reply to Gulliver)
       Post #: 21
RE: Best glow driver? - 8/21/2008 11:22 PM
Rune
Score: 100
Status: offline
As i see it ...the delayed start off the glow and possiblity to adjust both that and the "glowing" is the big thing here.
It also let you use any type off battery you want ....you can change if you want dont remeber the volt it need.
Rune Gjelsnes
Hide Signatures
(in reply to Mastertech)
       Post #: 22
RE: Best glow driver? - 8/22/2008 10:01 AM
Dave Harmon
Score: 101
Status: offline
quote:
ORIGINAL: Mastertech
The Radio South orange glow driver I have has a 7 second delay start.
It works great on the YS 170DZ.
Dave
Forget Mixing Your Own Fuel....It''s Easy But No Longer Needed!
Hide Signatures
       Post #: 23
RE: Best glow driver? - 8/22/2008 10:25 AM
najary
Score: 100
Status: offline
I have the Radio South driver and I wanted to continue using it, because it has many advantages. So I put a simple lamp switch in the middle of the wire, I hold the switch in my left hand together with the landing gear and flip it On or Off when I want to.
Regards,
Isaac Najary
Click for fullsize
Hide Signatures
(in reply to Dave Harmon)
       Post #: 24
RE: Best glow driver? - 8/22/2008 11:35 AM
Dave Harmon
Score: 101
Status: offline
quote:
ORIGINAL: najary
Regards,
Isaac Najary
Right...I think I have seen your driver before now.
My driver has the delay built in and is activated by the button on the driver....not in the wire.
So....I push the button, start cranking and 7 seconds later the glow comes on automatically and lasts for one minuite.
If the engine quits before the driver turns off, I just push the button again and the 7 second delay starts over.
Dave
Hide Signatures
(in reply to najary)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
