atsioukl
FL, USA Status: offline
Hi Calvin, I also own a Marutaka (a.k.a. Royal) Skymaster. Still working on mine. It's fully built but I still need to fiberglass the wing. Fuse is just about ready for paint. To answer your questions, the wood mounts that are included in the kit should be just fine. You could however cut off the blocks and install a custom motor mount. Do keep in mind though (as Pete mentioned above) that the firewall is only 1/8" ply. So, if you do it, use a 1/8" ply doubler for strength. Just curious - what type of power are you thinking of using? As for the bellcranks, they should be ok as long as there isn't lots of play in the connections. When I built mine, I scrapped the bellcranks and installed individual servos for each aileron and flap. The flaps are not standard on these kits. I built mine custom. I too am using Futaba 3004BB servos for everything except the throttles; in which case I use 2 tower mini servos. I built my wing as one piece. Therefore, the booms are not detachable. To operate the elevator and rudder, I ran a flexible pushrod down each boom. The pushrods exit on the inside of each boom near their respective control (i.e. Rudder or elevator). The other end of the pushrod ends up in the center of the wing. Each control (rudder and elevator) is operated by an individual servo in the center section of the wing. With that said, I have a total of 6 servos in the wing. Some of the other mods that I have made to my 336 are: -Replace original wire nose gear with Robart Strut -Added nav lights, landing lights, strobe, and beacon. -purchased the cockpit kit for this kit I would certainly like to keep this post going, so, if you have more questions, please post them or send emails (atsioukl@tampabay.rr.com) . Additionally, please remeber to post some pics of your progress! Anthony
