David Eichstedt -> RE: ***** New E Flite F16 400 DF (Thunderbird Scheme) ***** (11/6/2008 12:33 AM)
quote:
ORIGINAL: 29904 Where is Dave when we need him? Doesn't he have any solutions to suggest? Well I finally got my DX-7 programed for flap/ailerons and hope that will help on the landings. Believe it or not my complaint is not that it is too slow. I find that it is fast enough for me but I have to get used to the correct landing procedure. My concern is where the directions state to make sure you set the speed controller for a 2 pole motor but there is no easy way to assure that is done correctly with the E-flite Pro speed controller. Jogging the stick and counting confusing beeps doesn't get for me. After replacing the brand new E-flite Pro speed controller, another shot $45, with the Turnagy 40 amp that problem was eliminated. Dropping the nose in a turn. Probably a problem with all pusher type airframes that I will have to get used to and I will have to carry higher speed into my turns. Considered a workable rudder to counter the dropping nose but the encountered problems outweighed the benefits so that idea was dropped. Will post my next flight report as soon as the weather clears. Larry Been in China for 2 1/2 weeks, just got back last night. Currently am hitting a wall but I still need to stay up for at least 3 hours to force myself back into Central time. Not sure what to tell you about our ESC programming method except thanks for the feedback. The airplane you see in the video is completely stock with the recommended Thunder Power ProLite 2100 battery and 25A ESC. That's how we film all our products, using the recommended setups. We have not used radar or doppler to measure the speed, but many of us in the office have been flying jets for quite a while and we all estimate top speed in the 55-65mph range. Even with the ProLite, the cg does end up a little farther forward than we would have liked, but that was the best we could get. If you're using a heavier battery, you're going to need even more up trim, up control throw, and maybe even a little tail weight. You'll definitely need more up elevator in the turns. Much better to go with a lighter battery and keep a couple ounces out of the plane, which makes a big difference. This is most likely why someone in an earlier post had to bend his landing gear forward; too heavy of a battery. If this is your first jet, realize that it takes a lot more up elevator to get a jet to rotate. There is no propwash hitting the tail surfaces, so it takes pure airspeed to get control surface effectiveness. Sorry to hear so many people are having issues with the motors. All I can say is keep calling Product Support. As frustrating as it is to buy a product that leaves you disappointed, believe me it's ten times more frustrating when you're the one trying to develop a product that you think is going to be great and your customers end up disappointed.
