Biplane piches down at full power
Tower Hobbies
Logged in as Guest
  Printable Version
EASYTIGER'S NEW F-22 Raptor 70mm EDF SALE$179!
Seller:  EASYTIGER
Details:   $179.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Biplane piches down at full power
Page: [1]
Login
Biplane piches down at full power - 8/25/2008 3:56:33 PM
3dsky
Status: offline
Looking for a place to start. I have a 120 size biplane that flies true and level at ½ to full power upright and inverted (very little down needed) with a constant throttle setting. The plane pitches down (hard) when throttling up and once you correct the dive it will fly straight. What causing the down pitch at throttle up?
_____________________________
Skywriter Graphics,
SkyitoutRC.com
       Post #: 1
RE: Biplane piches down at full power - 8/25/2008 4:08:40 PM
Darryl Usher
Status: offline
I would look at too small stab and too much down thrust.
Darryl
Usher Tool
www.acsip.com/~dgu
(in reply to 3dsky)
       Post #: 2
RE: Biplane piches down at full power - 8/25/2008 5:33:26 PM
buzzard bait
Status: online
You say, "once you correct the dive it will fly straight". Does that mean that you are correcting it just with the stick and NOT with the trim? In other words, is it only the transition from low to high throttle that it the issue?
If so, I'm not sure what it going on here, but it sounds like the CG is fairly far back. If you move it forward some, then when you re-trim it will be carrying more 'up' elevator, which might solve the problem.
Excessive downthrust, as above could be contributing. With excessive downthrust and a rear CG, a blast from the engine would tip the nose down, and the plane would continue in a downward flight path because of the rearward CG. Jim
(in reply to Darryl Usher)
       Post #: 3
RE: Biplane piches down at full power - 8/25/2008 7:19:42 PM
3dsky
Status: offline
The pitch down is only on throttle up and with the stick and once I compensate for the pitch down it will fly hands off level. The CG is at recommended point and the 2 wings are at the recommended incidence. The plane is not over powered. I think the CG is OK because it will fly level upright and inverted with out a trim change. Thanks for your help, I was thinking of trying to add up thrust, but wanted I second opinion.
Skywriter Graphics,
SkyitoutRC.com
(in reply to buzzard bait)
       Post #: 4
RE: Biplane piches down at full power - 8/25/2008 8:19:32 PM
Rodney
Status: offline
What are the recommended incidence of the wings? On all my bipes (at least 11 with 6 being quarter scale) flew best when the upper wing had minus 1.5 degrees with respect to the lower wing. On most of mine the elevator and lower wing were at the same incidence and thrust line was always right about 3 degrees and downthrust varied on the planes from minus 3 to minus 5 degrees. You may find that minor changes in the incidence of the upper wing will greatly improve the performance.
(in reply to 3dsky)
       Post #: 5
RE: Biplane piches down at full power - 8/25/2008 8:35:32 PM
Villa
Status: online
I would add a little nose weight. If then still the same, I would add a little more nose weight. I have had only 2 biplanes and am now scratch building my third.
(in reply to Rodney)
       Post #: 6
RE: Biplane piches down at full power - 8/26/2008 7:02:11 AM
nitro wing
Status: offline
Check incidence,perhaps take some down thrust out (easy to do) retest
Level flight,power on and off,no pitch should be notable if seeking precise and extreme aerobatics.
(in reply to Villa)
       Post #: 7
RE: Biplane piches down at full power - 8/27/2008 4:25:22 AM
BMatthews
Status: offline
quote:
ORIGINAL: 3dsky
....I think the CG is OK because it will fly level upright and inverted with out a trim change.......
That may be normal for a hot aerobatic model or for the 3D flat foamie type models but it definetly is NOT normal for a regular sport model and is not at all OK for a scale model.
Not requiring any push to hold it level in the inverted means your CG is too far back and you're dab on the neutral point or VERY close to it. This is likely making your thrust offset highly critical and with a model set up for what basically amounts to 0% stability ANY downthrust is too much.
Now if this is on a 3D style hot aerobatic model then fine. If not then I'd suggest moving the CG about 3 or 4% of the wing chord ahead and retrim the elevator. I'll bet the odd behaviour on power up goes away.
Witty saying to be plagarized shortly.....
(in reply to 3dsky)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU2
