When engine runs servos begin to glitch
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> When engine runs servos begin to glitch
Page: [1]
Login
When engine runs servos begin to glitch - 8/26/2008 2:00:53 AM
skrez
Status: offline
Hi Guys,
I picked up my 1st giant scale airplane from a estate sale. The plane is a Byron Husky with ST 2500 engine. The plane was not flown in many years, still had a AM receiver and old style connectors on the servos. The servos are for giant scale, and I had to re-solder new connectors on them . The battery that I am using is a 4.8 volt 1500 mah . Do I need a 6 volt perhaps? When I do a range check without the motor running, all is fine. As soon as I start the engine, the control sufaces go crazy. The attena goes straight down and is outside the fuse, so what can my problem be? I never had this problems with any of the plane sI have owned?
Kind Regards,
Frank
       Post #: 1
RE: When engine runs servos begin to glitch - 8/26/2008 2:32:08 AM
Laird SS
Status: offline
Did you switch over to a dual-conversion FM receiver? Also, check for any metal to metal contact in the aircraft. Just a couple of ideas.
BB
(in reply to skrez)
       Post #: 2
RE: When engine runs servos begin to glitch - 8/26/2008 2:39:40 AM
skrez
Status: offline
Hi,
Yes ,I put a new dual conversion recever in. I have been thru the entire airplane and can`t find any metal to metal contact.
Frank
(in reply to Laird SS)
       Post #: 3
RE: When engine runs servos begin to glitch - 8/26/2008 4:30:52 AM
Bass1
Status: offline
Bypass the on/off switch and see if the problem persists. If the glitching stops, install a new heavy duty switch.
(in reply to skrez)
       Post #: 4
RE: When engine runs servos begin to glitch - 8/26/2008 10:45:11 AM
skrez
Status: offline
Okay I`ll try heavy duty switch. Do you think I`m still okay with the 4.8 volt battery or is it nessasary to go with 6.0 volts? I`m only using two gaint scale servos , rud. and elev. the rest are standard servos.
Frank
< Message edited by skrez -- 8/26/2008 10:47:53 AM >
(in reply to Bass1)
       Post #: 5
RE: When engine runs servos begin to glitch - 8/26/2008 5:30:04 PM
CK1
Status: offline
skrez , If the glitch only happens when the engine is running I dont believe changing from 4.8 to 6.0v is going to improve the situation.
I would check the throttle linkage to be sure that there are no metal to metal contact points ( clevis to throttle arm especially ) .
If there are no metal to metal contact points start isolating servos by disconnecting them one at a time and rechecking for the concern with the
engine running , this will isolate the cause to specific chanel where the interference is being induced . Possible causes could be a bad servo
pot effected only when the vibration from the engine is present or possibly a bad servo wire extension and the pin contacts are being etched by the
engine vibration .
Good Luck ,
_____________________________
"Aint this great !!"
Chris
(in reply to skrez)
       Post #: 6
RE: When engine runs servos begin to glitch - 8/26/2008 8:17:16 PM
Edwin
Status: offline
I've seen the exact scenaio you are describing. A guy brought in an old trainer that the servos went nuts with the engine running. Was a bad switch.
Edwin
(in reply to CK1)
       Post #: 7
RE: When engine runs servos begin to glitch - 8/27/2008 1:00:53 AM
TLH101
Status: offline
Yep, I missed a major fly-in several years ago, because I could not find a glitch with the engine running. Finally bypassed the switch and all was good. I guess the contacts in the switch were corroded, and lost contact due to vibration.
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to Edwin)
       Post #: 8
RE: When engine runs servos begin to glitch - 8/27/2008 10:58:29 AM
skrez
Status: offline
Hi Guys,
Thank you for all your input, I found the problem last night. I had an bad extension wire on the charge jack end of the swich harness that had exposed wire touching metal inside the fuse. I changed it and all the glithing went away. Thanks to all again.
Regards,
Frank
(in reply to TLH101)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU2
