USA V4 Electric - Bad Transmitter
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> USA V4 Electric - Bad Transmitter
Page: [1]
Login
USA V4 Electric - Bad Transmitter - 8/26/2008 2:02:44 AM
Royersford99
Status: offline
On Monday August 18th I purchased the 2 Channel USA V4 Electric 939-6-V4-Plane
Twin Motor Aircraft Ready to Fly!!. It arrived today and I quickly realized the transmitter is broken. I inserted 2 new sets of batteries and cannot get a power light. Kind of a bummer - I am new to the hoby and wanted to play around tonight. how do I get a new transmitter? My order number is: Order Number: yhst-17210252890263-52126
       Post #: 1
RE: USA V4 Electric - Bad Transmitter - 8/26/2008 10:57:21 PM
nitrostaff1
Status: offline
Please try the following when you insert the 8 AA batteries they are jointed in series. Please make sure all the connection on each ends of the battery are tighly connected. Please make sure there are no plays in between.
Let me know
John
Nitro Planes
_____________________________
--===www.nitroplanes.com===----
(in reply to Royersford99)
       Post #: 2
RE: USA V4 Electric - Bad Transmitter - 8/27/2008 1:18:04 AM
Royersford99
Status: offline
OK, I have no problem admitting when I am wrong, or an idiot. I did not realize the battery holder came out and that there was a "backside" to the compartment. I guess if you only install 4 batteries it naturally will not work. Your note trigger one of those "ah ha" moments and after looking at the insturctions for the hundredth time, I realized how big of an idiot I was in this instance.
Thanks for your timely reply and assistance. I will see if this flies in the morning.
(in reply to nitrostaff1)
       Post #: 3
RE: USA V4 Electric - Bad Transmitter - 8/28/2008 1:55:45 AM
Royersford99
Status: offline
UPDATE: I am not sure what the issue is. I have all the betteries in the transmitter. I turn the transmitter on and I get a solid red light completely full. I plug the charger cable to the transmitter then to the plane and I get the blinking light signifying the charge process. Once complete, I turn the transmitter on, then the plane, hit the power-up and no response.
Not sure what is happening now. But I am frsutrated.
       Post #: 4
RE: USA V4 Electric - Bad Transmitter - 8/29/2008 1:58:03 AM
nitrostaff1
Status: offline
do not plug anything into the charger plug of the TX because that is used for tested only at the factory. Do no charge your batteries on the TX. You must start your TX first and have the trottle lowered all the way down and then power on the plane. did you charge the battery for the plane?
John
Nitro Planes
quote:
ORIGINAL: Royersford99
       Post #: 5
RE: USA V4 Electric - Bad Transmitter - 8/29/2008 2:49:36 AM
Royersford99
Status: offline
John-
Yes, I charged the plane battery. At least I plugged the jack into the TX and then the plane and watched the red light come on and then go off after a while. When I plug the jack in again, the light does not come on, leading me to believe the battery is charged. I even pulled the battery out of the plane to make sure it was connected to the internal wiring. I do not rechargeable batteries for anything, so I have brand new duracell batteries in the TX. When I power up the TX, the red power light comes on - the throttle is powered down, I turn the plane on and power up and NADA.
Can you authorize a Return Authorization? Or, can I swap this for a replacement. I will try the other plane on Friday and see if it works.
Thanks.
       Post #: 6
RE: USA V4 Electric - Bad Transmitter - 8/29/2008 6:37:25 AM
nitrostaff1
Status: offline
alright rma issued.
John
Nitro Planes
       Post #: 7
RE: USA V4 Electric - Bad Transmitter - 8/31/2008 12:19:46 PM
Royersford99
Status: offline
Are you emailing me the RMA#? Or is it just in the system at Nitro??
Thanks for your help.
       Post #: 8
RE: USA V4 Electric - Bad Transmitter - 9/3/2008 4:10:43 AM
nitrostaff1
Status: offline
the rma information and the instruction on how to return the product has been sent.
John
Nitro Planes
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU2
