Brushless Rancho
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Himoto Racing Support Forum >> Brushless Rancho
Page: [1]
Login
Brushless Rancho - 8/26/2008 10:10:05 AM
guy4x4
From: Bakersfield CA now watford UK, UNITED KINGDOM
Status: offline
I'm wondering if a brushless Rancho conversion is possible but not sure about gearing and space I could get more space with these anyone have any ideas.
http://server.sohouniverse.net/~himotora/shopping/pgm-more_information.php?id=864&=SID#MOREINFO
Update found this http://www.amainhobbies.com/product_info.php/cPath/1_44_904/products_id/24952 witch is similar to Rancho layout I wouls have to get rid of throttle and brake servo can brushless motors stop like have braking ability look at lay out.
Click to see fullsize image.
Click for fullsize
< Message edited by guy4x4 -- 8/26/2008 11:22:02 AM >
_____________________________
HIMOTO RACING RANCHO UPGRADE PRO TAMIYA TNX 3.0 PRO CONVERSION TO 5.2R HSP SWARM
       Post #: 1
RE: Brushless Rancho - 8/26/2008 12:10:21 PM
HimotoRacingUSA
Status: offline
that should work but i am not 100% sure.
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to guy4x4)
       Post #: 2
RE: Brushless Rancho - 8/26/2008 12:19:33 PM
guy4x4
Status: offline
Im not sure either just need a motor mount and I can get it to work I think
(in reply to HimotoRacingUSA)
       Post #: 3
RE: Brushless Rancho - 8/26/2008 12:25:05 PM
guy4x4
Status: offline
Ive ordered a motor now need to find a esc here is the motor the 8xl http://www.offshoreelectrics.com/proddetail.php?prod=fei-540XL
       Post #: 4
RE: Brushless Rancho - 8/26/2008 3:33:39 PM
HimotoRacingUSA
Status: offline
Nice, you will have to keep us up to date on the progress and post some video.
       Post #: 5
RE: Brushless Rancho - 8/26/2008 5:28:42 PM
guy4x4
Status: offline
Will do also what size esc do think 120a.
       Post #: 6
RE: Brushless Rancho - 8/26/2008 5:37:23 PM
HimotoRacingUSA
Status: offline
lol, 120amp is a little over kill but why not
       Post #: 7
RE: Brushless Rancho - 8/27/2008 1:16:25 PM
muratt2007
Status: offline
my brushless Truck flips forward when i hit the breaks with 3S lipo...
you'll be amazed with brushless power...
p.s. : watch the heat...
< Message edited by muratt2007 -- 8/30/2008 6:17:49 AM >
       Post #: 8
RE: Brushless Rancho - 8/27/2008 1:36:40 PM
muratt2007
Status: offline
another thing came to my mind: you can use bigger pinion.
4S lipo should be fine... 2000KV X 16.8V = 35.000 RPM
< Message edited by muratt2007 -- 8/27/2008 1:38:26 PM >
(in reply to muratt2007)
       Post #: 9
RE: Brushless Rancho - 8/27/2008 9:41:57 PM
guy4x4
Status: offline
What pinion would be good 13t or 14t.
       Post #: 10
RE: Brushless Rancho - 8/27/2008 10:13:51 PM
guy4x4
Status: offline
I think I can run a 5s lipo ordered speed controller to here is pic.
Click for fullsize
       Post #: 11
RE: Brushless Rancho - 8/28/2008 7:23:17 AM
muratt2007
Status: offline
5S is not advised because of the extreme RPM you'll get. You can destroy the motor because of the unnecessary RPM. But people use it and they say its too fast, no need to be soo fast... also as i know 8xl has 40.000 RPM max revolution limit. so 35.000 seems to be the safe revo speed.
with 35.000 rpm you'll see that your rig is wild...
theres not much difference between 13 and 14 teeth pinions(for me) so you should go with the bigger pinion(14t).
also you may order and try a 16T pinion for testing heat and speed.
also can you can put a heat sink and fan so you can drop the heat(do it after starting to use the motor.)
you can put on a water jacket to the motor.( i dont know where you can find the pump)
another note: my truck is 41.000 RPM Brushless and i can never put on full throttle, so dont worry about more RPM... 35.000 will be too much also...
see video: http://www.vimeo.com/1101402
       Post #: 12
RE: Brushless Rancho - 8/28/2008 1:51:01 PM
guy4x4
Status: offline
Thanks for all the great info muratt2007 also thats a cool video If i get 4s lipo whats a good size 5000 battery thanks.
       Post #: 13
RE: Brushless Rancho - 8/29/2008 7:51:33 AM
muratt2007
Status: offline
8xl dont ask for much amp so you can use any fine lipo over 4500mah with 20-25C discharge rating. i use 4500Mah 20C Broadamp and they go good.
depending on your budget you shall get the highest C rating you can=25C and highest amp battery you can afford.
More technical info:
4500mah X 20C = 90 Amper/hour
4500mah X 25C = 112,5 Amp/hour
5000mah X 20C = 100 Ah
5000mah X 25C = 125 Ah
8XL will use around 20-25 Ah avarage and you'll get about 20 minutes of runtime. if you use small pinion your runtime will be more, if you use big pinion your runtime will decrease but speed will be much more.
also at acceleration your motor will draw high amp like 70-80 ampers.
The higher C rating and higher mah value and the better battery quality will mean longer runtime, longer lifespan of battery.
       Post #: 14
RE: Brushless Rancho - 9/2/2008 1:27:55 PM
guy4x4
Status: offline
