SnowOwl
Joined: 5/10/2003 From: Philadelphia, PA, USA Status: offline
Bipeflyer is right about the displacement classes for engine size. 1/2A is the size of the familiar Cox reed valve engines that came in most of their ready to fly airplanes. Incidentally, a Cox reed valve engine with the built-in tank like the Golden Bee, or Black Widow or Texaco might be a good choice for your Guillows Dauntless, because it wouldn't need a separate tank, making things simpler ahead of the firewall(1/8" lite-ply or a sandwich of 1/64 ply and balsa). They produced some with throttles if you can find one. It's a lot of power for a plane that size. A PeeWee .020 would be enough. You might try the old free flight trick of putting the prop on backward. When Guillows says 3/4 inch scale, they mean for every foot of full scale airpane there's 3/4 inch of model. In other words, 1/16 of full size. 3" scale is the same as 1/4 scale. This is a prety small plane, and will require lightweight gear, like sub-micro servos and something like the GWS GWR-4P 4 channel Pico receiver or the hitec Feather receiver. If you're financially comfortable look at the Berg DSP receivers. The receiver battery is too big. If you put "battery pack" in the search window of this site there are a couple of dealers who will spot weld up a 110 mah pack complete with connector if you tell them what kind of radio you are using. Your charger is O.K., but only leave them on charge for about three hours. You might need to arrange for there to be wood(1/8" balsa) at all the places where the control surfaces separate, small hard points(lite-ply or a sandwich of 1/64 ply and balsa) for control horns, and if the wing isn't designed to come off, you need to either arrange for that or some other hatch to get at the radio gear. Keep the paint to a minimum. A cheap airbrush might really be helpful. See if you can find clear nitrate dope for filling the covering and fuel proof dope for the last coat only. Fight to keep things light and this should be a fun plane. Practice with something fairly fast before you test fly, because this isn't going to be a floater no matter how much lightness you add.
