Velocity Stack Help ???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Velocity Stack Help ???
Page: [1]
Login
Velocity Stack Help ??? - 8/26/2008 6:22:25 PM
P47 Thunderbolt
Status: offline
I need some help. I have a G62 and Fuji 43 and both carbs stick out slightly from the cowl. After a flight, I have a lot of siphoned fuel and fule down the side of the plane. I picked up a couple velocity stacks from B&B which are fully radial adjustable. Where should the angle on the inlet of the stack be positioned? Facing forward, backward, up, down? Also, will there be high or low end needle setting changes required with the velocity stack?
       Post #: 1
RE: Velocity Stack Help ??? - 8/26/2008 6:46:04 PM
arobatx
Status: offline
The stack will certainly help with the carb spit. I've found that the slant cut type like B&B will tune differently pending the direction of the cut. So far in every example, I have installed it with the slant opening facing forward, and re-tune.
Chad
_____________________________
Chad
(in reply to P47 Thunderbolt)
       Post #: 2
RE: Velocity Stack Help ??? - 8/26/2008 8:21:31 PM
ram3500-RCU
Status: offline
Yes, facing backward will create a siphon or vacuum effect and not be good. Sideways or forward is best. Either way, you will probably need a little tweaking on the needles.
(in reply to arobatx)
       Post #: 3
RE: Velocity Stack Help ??? - 8/26/2008 10:54:42 PM
captinjohn
Status: online
YUP...get a air funnel from Horizon...around $2 nice! Capt,n
I never met a engine I did not like !
(in reply to ram3500-RCU)
       Post #: 4
RE: Velocity Stack Help ??? - 8/27/2008 5:42:55 PM
P47 Thunderbolt
Status: offline
Thanks guys for the info, this really helps. I should have the velocity stacks from B&B before the weekend.
(in reply to captinjohn)
       Post #: 5
RE: Velocity Stack Help ??? - 8/28/2008 9:14:50 PM
karolh
Status: offline
Don't forget to give us an update on just how the positioning of the stack and carb retuning went.
Karol
       Post #: 6
RE: Velocity Stack Help ??? - 8/28/2008 9:31:42 PM
arobatx
Status: offline
While we're talking about this...anyone have one of the Horizon Hobby black plastic funnels?...can you measure the opening at the carb end? I can't remember how large of a carb they'd be appropriate for.
Chad
Chad
(in reply to karolh)
       Post #: 7
RE: Velocity Stack Help ??? - 8/29/2008 2:12:14 AM
Super08
Status: offline
I have the aluminum angled stacks on both of My Fuji 43's. I have the opening angled forward and it stopped 95% of the fuel spit back out of the carb. It went from seeing a fog of fuel spraying out making a large mess down the side to a very light mark at the end of a days flying. Here is a quick pic of the one on my Stick.
Click to see fullsize image.
Click for fullsize
If I buy one more engine it''s going to hurt more than my wallet if my wife gets ahold of it.......
       Post #: 8
RE: Velocity Stack Help ??? - 8/29/2008 3:08:09 AM
tkilwein
Status: online
I mounted mine backwards and it runs good.
Going to flip/re-tune and see if it runs better after reading this thread.
Click for fullsize
Click for fullsize
(in reply to Super08)
       Post #: 9
RE: Velocity Stack Help ??? - 8/30/2008 8:48:43 AM
2engsout
Status: online
Hi Guys, I have G-45's on my Ziroli DC-3 and I could tune for a smooth rpm all the way thru the rpm range on the ground, but at 1/2 throttle in the air, the prop was unloading so much that the engines would really go rich and 4 stroke big time. Raising the popoff did'nt really help, so I angle cut the black plastic velocity stacks that came with the engines at 15 degrees forcing the air into the motor and that really helped lean the mixure at 1/2 throttle in the air, cleaning up that 4 stroking. Tuning on the ground with a load on the prop, the engine requires more fuel at 1/2 throttle than in the air at 1/2 throttle. At 6o mph, there is not enough prop load on the engine at 1/2 throttle to burn the amount of fuel entering the engine, thus you get 4 stroking. That carb hangs all the way out into the wind on that DC-3. The angle cut forces slightly more air in the carb, thus leaning the mixure. Hope this helps Rick Simmons
(in reply to tkilwein)
       Post #: 10
RE: Velocity Stack Help ??? - 9/2/2008 11:10:04 PM
rcnutstoo
Status: offline
I have a Q50 with an angle stack the short cut is at the rear. let us know how this all turns out cause now I'm thinking of turning mine to face forward too, as I also get a 4-cycle at midrange and on downline. Cap 232 by lanier only the end of the stack sticks out of the cowl.
(in reply to 2engsout)
       Post #: 11
RE: Velocity Stack Help ??? - 9/3/2008 3:20:11 PM
Big_Bird
Status: online
I use a B&B stack on my G62 in a Giant Aeromaster. It faces forward and got rid of most of the fuel spray. When I put it on I had to lean the engine a bit because the fuel spray was being sucked back in.
Click for fullsize
Ken
WACO Brotherhood #70
(in reply to rcnutstoo)
       Post #: 12
RE: Velocity Stack Help ??? - 9/7/2008 3:24:43 PM
P47 Thunderbolt
Status: offline
Got several flights now on my Fuji43 with a B&B velocity stack facing forward. 90% of the spray is gone. Still getting some on the stab but much, much better compared to before. I also had to lean the motor slightly.
(in reply to Big_Bird)
       Post #: 13
RE: Velocity Stack Help ??? - 9/7/2008 8:42:17 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: tkilwein
I think you will see an improvement, but please let us know how it goes.
       Post #: 14
RE: Velocity Stack Help ??? - 9/23/2008 4:54:31 AM
Peter_OZ
Status: offline
I tried the Great planes version on my G62 that is fitted to a Vailly 90" Seafury. With it fitted I was losing 300rpm on the ground.
Mind you the stack does not extend right out into the airflow, only the tip sticks out past. I did try it with cowl off but saw no improvement.
I'm after an increase in RPM with this excercise.
Wondering how the Zenoah air funnel might help? Any ideas?
What length is the B& B air funnel and where can I get one?
ta
cheers
Peter
www.petenplanes.com.au
