altavillan
CA, USA Status: online
A Castle Creations SC is my choice, mainly for the ease of programing it on the computer. (need the cord and software too). The 42-50 motor they suggest should be concidered a first choice. GP motors have their drawbacks (mainly whiney noises in flight, a bit weak where the can mounts to the shaft) but they are probably only bettered by Hacker and Axi. The good side of GP Reactor motors is, cheap, excelent power to weight, reduced shaft end size allows a smaller prop adapter for evan more weight savings, simple bearing removal and replacement, a ready supply of spare parts like only Tower can do. I use 26ga. telephone wire and extand my leads rather than heavy extension wire. Buy it at radio Shack. Your Dx7 and 6100 will work fine. You should be able to do a split elevator with it. Then you want a pair of these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNCV9&P=0
_____________________________
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
