cold_reboot
TX, USA Status: online
+1. The only thing I use epoxy on are firewalls, landing gear mounts, elevator and rudder. CA for everything else. Thin CA works great for sheeting, tac it down with Thin then I'll use Medium CA for strength (usually a filet). Medium CA is also gap filling, which is a plus. Makes the building a lot faster since the cure time is so short, but medium, and more so thick, give ample repositioning time should you need it. Thin is pretty much instant as you'd expect.
_____________________________
Caster Racing K8T, TTR ST-1, Spektrum DSM Sig 4*40, GP Corsair, Top Flite P47D Razorback, Spektrum DX7
