Findind the lost ark? easy Finding the lost spark? now thats tough ! MYSTERY SOLVED !!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Findind the lost ark? easy Finding the lost spark? now thats tough ! MYSTERY SOLVED !!!
Page: [1] 2   next >   >>
Login
Findind the lost ark? easy Finding the lost spark? now... - 8/27/2008 1:39:53 AM
foodstick
Status: offline
Ok, I hope I don't get to rambling on what I have tried ( to no avail) but here it goes..
I have a 46cc poulan on the test stand that won't spark/run. It hasn't even made a weak pop.... Now, I have two other of the same motor that I am used to working with ,and they are for the most part rock solid running machines.
Here is the story up to now,
1 The motor ran , but poorly with seemingly bad carb needle settings in the saw.
2 stripped saw, turned carb for better pushrod access, pulls fuel great when choked.
3 Aftermarket exhaust same as other motors.
4 Gas is not old, smells ok.
5 Switched flywheel to 3 magnet type, with 3 magnet coil,small lobe in flywheel was gone, but I carefully aligned flywheel and crank, and smeared a thin coat of jb weld to surfaces, torqued down good.
6 Choke motor, open throttle,hand pull it 5 turns, lower throttle, spin up with 24 volt starter....nothing ....numerous times.
7 I tried another coil..still no spark, pulled coil from a great running motor, no spark
8 Checked coil flywheel gap, set by placing doubled over paper as shim as usual..still nothing
9 Pulled plug from good running motor ...nothing
10 Kill switch wires are off and clear, no apparent shorts possible that way.
11 the motor does seem to be spinning very easy with the starter, might need some oil shot in the plug hole ?
12 Also when spinning up motor with higher throttle setting you can hear that heavy muffled sound that says its getting fuel.
13 I also checked the fuel filter screen in the carb, clean..I haven't opened the diaphragm side since it seems to be pulling.
I think I am honestly still forgetting things I have tried, It has to be something so obvious...even a stuck ring or an internal problem should have sparked at least once I would think?
Thanks for any help..I know this is a doozy of a post !
< Message edited by foodstick -- 9/4/2008 12:20:40 AM >
       Post #: 1
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 1:56:12 AM
billzair
Status: offline
how about a new spark plug? sometimes a crappy running engine has a plug that is fouled just enough to still be runable but will never reach full rpm and run eraticly. or could your coil be grounding out somehow?
_____________________________
If it came from a chainsaw or weedwacker, its GOTTA be good.
(in reply to foodstick)
       Post #: 2
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 1:59:43 AM
foodstick
Status: offline
I did pull the plug from one of my best motors and installed it..along with the coil from same motor.
(in reply to billzair)
       Post #: 3
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 2:47:43 AM
billzair
Status: offline
what happens when you take the plug out, ground it out on the cylinder and turn the engine over?
Maybe you should put the orginal flywheel and coil back on and give it a shot?
I wouldnt worry about a stuck ring and such until we can figure out why your not getting any spark at the plug.
       Post #: 4
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 4:09:16 AM
buck1856
Status: offline
ld first try and get spark like said.Its either the coil,or the plug.But the flywheel and coil must match,a pair.To make the engine run right the flywheel must be at the right position.But you can put the flywheel at any position you want on the crank and it should fire as it passes the coil no matter what its timed at.Did ya look in the rubber boot on coil and make sure the metal plug that fits over the plug is there.Is the cap screwed on tight.I had a twin that wouldnt run right somtimes and the plug was new.Tried it at night and you could see a sprk[very small]coming from between the insulator and hex head once in a while and would short it out.
       Post #: 5
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 5:50:52 AM
foodstick
Status: offline
I will try to see if I can do the sparkplug on top of the motor tomorrow if I can get help as it wouldn't be possible alone..However the last test I did with the motor was using the coil and sparkplug from possibly the best running poulan 46 I own? All of them are three magnet versions, and the motor I am stealing parts off of to test with was running like a champ just a week ago.... I tried using one of those inline sparkplug testers but seems to have a bad bulb in it...
(in reply to buck1856)
       Post #: 6
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 6:09:49 AM
buck1856
Status: offline
When your doing this switching around,maybe the engines are different mounting patterns.See if one of the kill tabs or small lugs are touching somthing thats grounded or the screws are different.It is impossible to take a working ign from one motor and put it on another identical motor and then have it not work unless somthiong isnt bolting up right or somthing grounding out.
       Post #: 7
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 4:40:56 PM
foodstick
Status: offline
Well this morning I tried the sparkplug on the top of the head, and it did spark, I have no idea why it won't pop in the engine. before reinstalling the plug I covered the hole with my thumb and turned the prop by hand,,it has great compression and vacumn. I drained my tank, and poured in gas from my current batch I am running. It is fresh as I seldom mix more than a gallon at a time. spun the motor up ...no ignition, choked it,spun it up..fuel is pulling very well to the carb..Got it wet ..took off choke , turned and turned and turned it with starter, at many different throttle settings, absolutely nothing... I wouldn't be surprised if the carb needs a kit in it..but I don't understand the problem ... I even pulled the plug and shot some fuel directly in the cylinder, same result ..zero ignition....
I don't think it is possible I am flooding it every time as I have tried starting it without any choke, Although now that I think of it I have never got it wet enough to see any gas slop out the exhaust tubes .
< Message edited by foodstick -- 8/27/2008 4:45:48 PM >
       Post #: 8
RE: Findind the lost ark? easy Finding the lost spark?... - 8/27/2008 9:51:09 PM
billzair
Status: offline
I bet the timing is some how different between the two fly wheels. you got spark...its problity just happing at the wrong time.
       Post #: 9
RE: Findind the lost ark? easy Finding the lost spark... - 8/27/2008 10:03:48 PM
microsprint9
Status: offline
This has nothing to do with your ignition problem, but i see above you said you flipped the carb, there is a small hole that runs from the crankcase to the pump in the carb, make sure it still has a path to the carb, it was my downfall on my first conversion.
       Post #: 10
RE: Findind the lost ark? easy Finding the lost spark... - 8/28/2008 2:14:02 AM
captinjohn
Status: offline
PRIME IT...through the carb....bout 8-10 drops....then see if if pops off! Capt,n
I never met a engine I did not like !
(in reply to microsprint9)
       Post #: 11
RE: Findind the lost ark? easy Finding the lost spark?... - 8/28/2008 2:45:17 AM
buck1856
Status: offline
Maybe the motor your trying is off a blower.Try spinning it CW rotation.Also as stated make sure the pulse hole is lined up.
       Post #: 12
RE: Findind the lost ark? easy Finding the lost spark?... - 8/28/2008 3:44:02 AM
foodstick
Status: offline
Its definately a chainsaw motor as I took it apart myself, and the carb pulse is pulling fuel perfect, you can see it come up the fuel line about 2-3 inchs per revolution when choked. I did prime straight through the sparkplug hole earlier today without results, Tomorrow I will try squirting straight in the carb throat, even though you can hear it sucking fuel when you put the starter on it at about 1/4 throttle...
I must admit I can't seem to wrap my head around what the problem is..If I had any problem with the TWO OTHER IDENTICAL MOTORS, I wouldn't be so surprised...
Oh well, I guess if there was no challenge to rc airplanes... there wouldn't be any reason to be in the hobby !!! ha ha
       Post #: 13
RE: Findind the lost ark? easy Finding the lost spark?... - 8/28/2008 4:03:25 AM
buck1856
Status: offline
Maybe one of the motors is a different year or somthing.Ive only come across this once or twice but the keyway when placed pointing at the 12 oclock position the piston was NOT at TDC.[dont remember what engines].Check and see if when you bring the piston up to TDC on all 3 engines the keyway is in the same position on all 3.when at TDC the magnets should be on or about the left side of coil.No matter where the keyway is if its different.
       Post #: 14
RE: Findind the lost ark? easy Finding the lost spark?... - 8/28/2008 5:02:08 AM
