Wild YFZ 450
Joined: 12/10/2006 From: toms river, NJ, USA Status: offline
All depends on how fast you wanna go and how much money you have... A good E-revo setup will be CRAZY.. You can get almost 60mph out of a truck that big and acceleration you could not even believe... But then again its going to run you almost 1000 dollars...( E-revo, MMM, Neu, 6s) But since you have said you are not running Lipos I would say your looking at atleast 700ish With the Castle MMM Combo and running your own 7 cell Batts... If your only going to be running 7 cells I wouldn't get a MMM waste if you ask me.. The Mamba Max can easily handle that.... A good cheap setup would be a MM with a 8l or so wiich wouldn't cost much more then 200.. If i where you, I would convert my Revo that you sayed you had or buy a E-revo roller off of Ebay to save some money.. Honestly the MM + 8l should be pretty good.
_____________________________
LST2, E-savage, Jato, 4-Tec, Mini-t, Micro-t Blade 400, Blade CX2, Blade MCX
