RE: HL Panzer IV upgraded to recoil and DBC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: HL Panzer IV upgraded to recoil and DBC
Page: <<   < prev  1 [2]
Login
RE: HL Panzer IV upgraded to recoil and DBC - 8/31/2008 10:06:21 PM
borealis
Status: offline
I almost finished painting and took the baby out for a duel with my DBC-equipped panzer III, as well as for a sound check at maximum volume. After returning home I added the turret numbers and insignias.
Indoor...
...and outdoor
(in reply to bhop73)
       Post #: 26
RE: HL Panzer IV upgraded to recoil and DBC - 8/31/2008 10:11:52 PM
blitzkrieg65
Status: offline
Really nice Borealis, it looks like steel, and the rust job on the mufler is amazing!
The Blitz
(in reply to borealis)
       Post #: 27
RE: HL Panzer IV upgraded to recoil and DBC - 8/31/2008 10:33:23 PM
icemonkey
Status: offline
very nice , a credit to you ,you can almost hear the clang as the hatch shuts !
_____________________________
deutsch moggies all the way !!!!!
       Post #: 28
RE: HL Panzer IV upgraded to recoil and DBC - 9/1/2008 7:36:41 AM
borealis
Status: offline
quote:
ORIGINAL: blitzkrieg65
The Blitz
The steel, translucid effect is obtained by spraying a coat of chrome silver before the coat of German Grey.
I don't know if it's a common tecnique, but I like to use it on non-camouflaged models.
Click to see fullsize image.
Click for fullsize
(in reply to blitzkrieg65)
       Post #: 29
RE: HL Panzer IV upgraded to recoil and DBC - 9/1/2008 8:22:41 AM
blitzkrieg65
Status: offline
quote:
ORIGINAL: borealis
The Blitz
Thanks borealis, I think I am going to try that on my New Stug, and maybe even go back to my oil blown Tiger 1 where I got carried away with the flat black on it!
What is German Grey do you have a paint color number or is it a Tamiya color?
The Blitz
       Post #: 30
RE: HL Panzer IV upgraded to recoil and DBC - 9/1/2008 9:03:19 AM
borealis
Status: offline
Yes, it's Tamiya's XF-63, also known as 'panzergrau' but Tamiya's name is 'German grey'.
       Post #: 31
RE: HL Panzer IV upgraded to recoil and DBC - 9/1/2008 2:33:59 PM
YHR
Status: offline
quote:
ORIGINAL: borealis
The Blitz
Yes I started doing this as well. I paint the tank with a finish called hammered steel, then a coat of redbrown primer, followed by German grey. It really makes convincing paint chips when you use a small flat tipped screw driver to distress the paint, and you can see the layers
       Post #: 32
RE: HL Panzer IV upgraded to recoil and DBC - 9/1/2008 3:41:53 PM
borealis
Status: offline
quote:
ORIGINAL: YHR
If you omit the red primer maybe you get a more 'steel' effect, but lose the higher realism in paint chips. But the method is great to reproduce very thin scratches too: I too used a small flat screwdriver, as well as a small saw (those used on the hobbico handles) to make very thin stips.
I find it more realistic, since you reproduce the same wear process found in real world.
(in reply to YHR)
       Post #: 33
RE: HL Panzer IV upgraded to recoil and DBC - 9/19/2008 2:55:21 PM
borealis
Status: offline
I just added the track tensioner from www.tank-modellbau.de.
The new lower position of the idler allowed me to lower the 4th return roller to a more correct position.
Now the tracks have the correct shape around the wheels.
Some pictures of the assembling process, and the final result.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: HL Panzer IV upgraded to recoil and DBC - 9/19/2008 11:55:59 PM
philipat
Status: offline
Looks great! How much did you lower the return roller? And, how hard was the tensioner to install?
       Post #: 35
RE: HL Panzer IV upgraded to recoil and DBC - 9/20/2008 8:23:20 PM
borealis
Status: offline
The return roller was lowered about 3mm.
The track tensioner is quite easy to install: you just have to cut a bit, drill a bit, and you are fine. You can do it in an hour of work or little more.
Most of the job was cutting the return roller support without destroying it, and re-mounting into the new position.
(in reply to philipat)
       Post #: 36
Jump to:
