Foxy
Joined: 3/23/2005 From: Kingston UK, but living in Athens, GREECE Status: offline
Sounds like it's the overdrive ratio. A rear oriented overdrive will cause exactly what you describe, understeer in the mid corner, over steer on power. Apart from that, the usual things apply in order to increase rear grip... stiffer front sway bar, more rear camber, less rear toe, softer springs and damping, slightly higher ride height at the back (.5 to 1mm higher than the front). What tires are you using? If foams, what shore, and what diameters? PS. Off throttle oversteer is usually not enough (rear) droop.
< Message edited by Foxy -- 8/27/2008 3:16:53 PM >
_____________________________
Foxy. RCU Car Forums Moderator. "Artificial Intelligence is no match for genuine stupidity". Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
