nitrosportsandrunner
ME, USA Status: offline
as long as you gear the vehicle right, itll be fine. i had a 15t fireball, and it was pretty fast for the money. but, a put it in a second vehicle and geared it alittle high. it overheated. i later bought a speed gems 15t motor, used it in the same vehicle with the same gearing and it lasted a long time. so, im saying the venom motors are less tollarent of heat than higher quality motors, but a decent power. honestly tho, if you spend 15-20 dollars more now, you will likely get a motor that will last alot longer.
_____________________________
VXL on 3s lipo, wheely king crawler, tt01 drifter
