DanSavage
CA, USA Status: offline
quote:
ORIGINAL: skoda450 Gary, Yes I protect from the top as you suggest prior to applying but my problem is getting them to stick to the shrink covering. My experience is that ANY amount of pressure to the decal after it should be set causes it to peal away from the covering. There is no adhesion between the decal and the covering. I don't want to spray the covering with the clearcoat. I guess I am looking for something that will produce the same properties as adhesive tape for water slide decals after they are applied. Try temporary tattoo kits. They are applied to waterslide decal paper, yet use a pressure-sensitive adhesive that is quite tenacious. Once they're stuck down, they won't want to come up ever. While they aren't truly fuel-proof, they do not require a clear-coat as the decal film itself provides the sealer. Dan
< Message edited by DanSavage -- 9/4/2008 7:41:17 AM >
