Yard bee gasser
Tower Hobbies
Logged in as Guest
  Printable Version
Meister Scale FW 190 D9 - RTF
Seller:  1958 cadillac
Details:   $3,100.00   |  11/20/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Yard bee gasser
Page: <<   < prev  1 [2]
Login
Yard bee gasser - 5/25/2003 11:43:58 AM
Bipe Flyer
Status: offline
That sounds good, but I'd go with a 2oz tank and stick with the 7X3 for the .074.
_____________________________
1/2A all the way!
Club Saito #151
(in reply to GotCoffee66)
       Post #: 26
Yard bee gasser - 5/25/2003 9:21:59 PM
GotCoffee66
Status: offline
I was thinking of the 2 oz and looked at them when I was at the LHS. Had it in my hand and almost bought it. LHS is too far to go back to so next Tower order, I'll probably get a 2 oz. According to the Norvel site, should last about 6 min WOT on one oz.
Ray
       Post #: 27
Yard bee gasser - 5/25/2003 11:43:02 PM
RysiuM
Status: offline
I have 2 oz tank in my Bee, not because I need it (I can get at least 15 min full throttle on BigMig .061 from it), but because it was the lightest tank I could get. I don't remember the brand, but this is the kind that has 2 plastic nipples (vent and optional fueling line) and one small hole for the cork with engine line. This empty tank weights less than 1/2 oz - all other brands weight at least 1 oz empty (even 1 oz size). So my choice was not the capacity, but the least total flying weight.
And you are right. .074 will fly fine on 7x3. But I suggest at least to try 7x4 because you might get a better thrust. You will never find out unless you try it.
I calculated that 6x2 on .061 I will bet the best static thrust, but I couldn't get unlimited vertical. So I tried 7x3 and it turned out, that it is the best choice. So don't trust your calculations - try different props, put them on the plane and fly it. See for yourself, what is the best choice.
RysiuM
< Message edited by RysiuM -- May 25 2003 6:51PM >
       Post #: 28
Yard bee gasser - 5/25/2003 11:53:24 PM
GotCoffee66
Status: offline
The fuel tank I got is a Sullivan round tank. Weighting it on the cheap Wal-Mart scale, it weights about an ounce in the bag. The one you have, is it round, square or a slant? Clear or white plastic? I have just about all the 2 oz tanks on my wish list a towers and none has a weight. LHS had the Sullivan square with the orange label so probably about the heaviest one made.
Ray
       Post #: 29
Yard bee gasser - 5/26/2003 5:29:51 AM
Bipe Flyer
Status: offline
RysiuM
The tank you described is a Hayes. They are the best small tanks available IMO.
A 7X3 will produce more thrust than a 7X4.
1/2A all the way!
Club Saito #151
       Post #: 30
Yard bee gasser - 5/26/2003 11:53:03 AM
RysiuM
Status: offline
[QUOTE]Originally posted by Bipe Flyer
RysiuM
[/QUOTE]
By the book, you are right. Less drag gives more rpm therefore more static thrust. That's the theory. By this rule I put 10x4 on my PBF (to got the most static thrust from my old COMO 40). It was flying kind of well. But when I broke the prop and had nothing else, that 10x6. I tried it. It was the blast.
I think, that even with more (by theory) static thrust, 10x4 didn't give "enough wind" . 10x6 made my PBF fly like PBF supposed to.
I don't want to argue with you. I have never tried Norvel .074 and I'm sure you are right: 7x3 works much better in your application. My point is, it doesn't hurt to try. O yes, it cost $1.50 for the prop if it turns out to be not good at all. But in some airplane configuration it might be worth to experiment a little. Especially in a "fun type" planes.
I have other plane with .061 (scratch built PZL-104 Wilga) and of all props I tried this little baby likes 6x2 the most, which just didn't work on my Bee at all.
I'm sure 7x3 will be the best starting point, but what the heck, try other and feel how you Yard Bee flies.
RysiuM
       Post #: 31
Yard Bee Engine - 5/28/2003 5:54:12 PM
FrancisPerson
Status: offline
My first Yard Bee weighed 14 oz (HEAVY Clancy wood) and used a PAW .03 diesel r/c. It was plenty peppy and lots of fun. I now have an electric powered Yard Bee built from plans with wood that I selected (Sig contest balsa) and it weighs 10.5 oz. It is a great airplane. A norvel .074 would be way over the top power wise and the weight would be good. A light weight Yard Bee is a Joy to fly. Try a Norvel .061 and keep the weight below 11 oz and see what I mean. The PAW .03 weighs 2.3 oz. A Norvel .061 weighs 1.8 oz. KEEP it LIGHT !!! You will love the results.
Oily in Germantown
Francis
       Post #: 32
Yard bee gasser - 5/28/2003 8:30:14 PM
GotCoffee66
Status: offline
I rec'd my radio from tower yesterday and the battery pack it came with weights 2 oz on my cheap scales. Is there a lighter battery back I can get or is this normal? The flight pack info is below
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXUZ92
Ray
       Post #: 33
Yard bee gasser - 5/28/2003 8:36:10 PM
BuzzBomber
Status: offline
There are 110maH and 150 maH Nicd Rx packs available. They will be lighter, but the drawback will be shorter time between charges, obviously. These packs will weigh about 1.2 or 1.3 oz. IMO, I bet you'll be fine with the 270 maH pack they gave you. SRbatteries or Balsa Products or Aeromicro should also have what you're looking for.
< Message edited by buzzbomber -- May 28 2003 3:43PM >
Matt Smith
If you're not having fun with this hobby, you're missing the point.
       Post #: 34
Yard bee gasser - 5/28/2003 9:21:16 PM
Digger-RCU
Status: offline
Because everybody needs to give their input.
For the 074 norvel, I have found that in most situations, I like the APC 6.3x4 seems to give good speed and nice torque. I have run apc 7x4 on my 074's, but they bog down and heat up.
for the 061, I like the apc 5.7x3 this little prop gives good torque, while keeping the engine spinning nicely. I have run smaller props for all out speed, but the 5.7x3 seems to work great in most situations.
I stay away form most Master I'mscrewed props for the norvels. they just dont seem to produce enought power for the given application.
Generally speaking I have found that for the norvels, they seem to like to spin FAST. If you overprop them, and they slow down, you will be losing power and getting too hot.
Randy (Digger) Birt
No black, No white, Just the Blues
       Post #: 35
Yard bee gasser - 5/28/2003 9:40:13 PM
BuzzBomber
Status: offline
Hey digger,
quick question for ya. I've got a coupla norvels I haven't even run up yet, and I've seen the consensus is that they like APC props better. The APCs I've seen at the LHS (sheesh, enough acronyms ) have the hole drilled larger than the propshaft on the norvels, ie it would fit my OS .10. Have you seen APCs with the right hole, or do you shim them with fuel tubing or something similar? GotCoffee, sorry to hijack your thread like that.
Matt Smith
       Post #: 36
Yard bee gasser - 5/28/2003 10:32:28 PM
RysiuM
Status: offline
[QUOTE]Originally posted by buzzbomber
There are 110maH and 150 maH Nicd Rx packs available. They will be lighter, but the drawback will be shorter time between charges, obviously. These packs will weigh about 1.2 or 1.3 oz. [/QUOTE]
For small and light planes I use 5 x 370mAh NiMH. They weight about 1.2oz, 6V gives extra torque and speed from micro servos.
For even lighter applications (like 5oz plane) I use 4 x 150mAh NiMH. The pack weights about 0.4 oz. I found, it has have enough current for 2 HS-55 + GWS receiver and charge last for a couple flights.
And yes, keep it light. This Monday I had very intense take off with my Bee. Wind gust slammed it to the ground, but because it's light there were not even a scratch. I started engine and I was flying again.
RysiuM
       Post #: 37
Yard bee gasser - 5/28/2003 10:41:23 PM
Bipe Flyer
Status: offline
I always use the Hitec pack you posted. If I want to save weight I get a 270 NiMH pack so I can use the same charger.(non-peak)
Yes you need to bush the APC props. A piece of fuel tubing works fine. A couple of layers of heat shrink tubing over the bolt works also.
1/2A all the way!
Club Saito #151
       Post #: 38
Yard bee gasser - 5/28/2003 10:52:58 PM
BuzzBomber
Status: offline
thanx, bipe flyer. I was just a little apphrehensive...thinking about vibration at high rpms if I did it incorrectly.
Matt Smith
