Air leak beneath Heat Sink?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Air leak beneath Heat Sink?
Page: [1]
Login
Air leak beneath Heat Sink? - 8/28/2008 2:47:11 AM
duratraxrc
Status: offline
I have had a very hard time lately getting my duratrax nitro evader bx dtx 18. to start and I noticed that I have lost compression and I figured it was the piston and the sleeve but just a second again I realized there was bubbles coming from underneath the heat sink everytime the piston reached the top of the sleeve, like that gasket underneath there is bad, is it possible that if that metal gasket is bad that it will cause bad compression and cause my rc not to start or......to start but everytime I let off the gas completely the car stalls.....the flywheel is easy to spin is why I am saying it may be compression
_____________________________
Be sure to visit my Duratrax Homepage at www.myspace.com/duratraxrc for some great information about duratrax.
       Post #: 1
RE: Air leak beneath Heat Sink? - 8/28/2008 2:56:58 AM
twomanytoys
Status: offline
The gasket is what holds your compression in. If it leaks in any way you will have problems. Get a new gasket and retighten your head bolts.
J et A ssisted T ake O ff
(in reply to duratraxrc)
       Post #: 2
RE: Air leak beneath Heat Sink? - 8/28/2008 5:09:59 AM
dkastil
Status: offline
that could be bad if it sucked dirt into your combustion chamber it could have over a few runs grinded your shizzel for nizzel .one of your head screws just got loose i bet they vibrate loose you have to check alot .
(in reply to twomanytoys)
       Post #: 3
RE: Air leak beneath Heat Sink? - 8/29/2008 3:26:19 AM
duratraxrc
Status: offline
I actually got it running right today, I changed the glowplug and put in a OS A3 Plug and it started right up and ran...probably better then it ever has for the most part, I think I am still running a little rich because it doesn't have the giddy up that it should..takes a second to get up to speed
(in reply to dkastil)
       Post #: 4
RE: Air leak beneath Heat Sink? - 8/29/2008 5:12:05 AM
dkastil
Status: offline
good to hear it is not fryed
       Post #: 5
RE: Air leak beneath Heat Sink? - 8/29/2008 3:38:11 PM
duratraxrc
Status: offline
No kidding, it's a little slow on take off but it idles good now....so I think the reason for not taking off fast is probably because I am running to rich. I'm going to fiddle with all of that later on today
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU2
