Any idea how to adjust reciever on 5#10?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> Any idea how to adjust reciever on 5#10?
Page: [1]
Login
Any idea how to adjust reciever on 5#10? - 8/28/2008 4:17:29 PM
Cridom
Status: offline
I adjusted it a little on the sensitivity the other day cuz my upper rotor was spinning slower but it still has some play any ideas?
thanks
       Post #: 1
RE: Any idea how to adjust reciever on 5#10? - 8/28/2008 8:00:48 PM
klaze
Status: offline
Some play? Huh?
So when you lift the heli it rotates on it's axis either left or right?
(in reply to Cridom)
       Post #: 2
RE: Any idea how to adjust reciever on 5#10? - 8/28/2008 8:17:13 PM
Cridom
Status: offline
nope actually when I make it rotate right (right rudder) the upper rotor would spin real fast and lift fast but if I turn left the motor seems to turn off ( the motor from the upper rotor)
any ideas?
(in reply to klaze)
       Post #: 3
RE: Any idea how to adjust reciever on 5#10? - 8/29/2008 12:10:51 AM
klaze
Status: offline
Just going to start at the basic stuff before assuming something as malfunctioning..
Is everything wired properly ?
       Post #: 4
RE: Any idea how to adjust reciever on 5#10? - 8/29/2008 1:20:59 AM
Cridom
Status: offline
I havent changed anything and it was working properly before.
no idea what it could be.
(in reply to klaze)
       Post #: 5
RE: Any idea how to adjust reciever on 5#10? - 8/29/2008 3:59:03 AM
Bashnbreakalot
Status: offline
Hello,
I have just received my own 5#10 and experienced the same problems. It seems that I have to center my trims on my transmitter every time I use a new battery and re-trim in flight. I have not adjusted the receiver yet. Maybe you can remember where you adjusted from and put you settings back.
I have not done any research into this problem so far but this solution allows me to hover for a whole charge (battery). I don't know if this will solve your issue or if there is another solution but try it and see what happens if you have not already done so. Also it seems that the charger that came with the kit was faulty and not charging my battery to capacity so I had to start using my superbrain 977 charger and that helped some also. In fact it seemed to help quite a bit now that I think about it.
< Message edited by Bashnbreakalot -- 8/29/2008 4:26:45 AM >
_____________________________
CEN Genesis LE w\Jumbo Kongs, Associated RC10GT RTR with O.S. 18CVRX, E-Maxx stock, RC18MT mambafied w\5400k, Losi Micro-t.
       Post #: 6
RE: Any idea how to adjust reciever on 5#10? - 8/29/2008 5:55:30 AM
Cridom
Status: offline
Ive tried that and it works but I dont think we should do that I want too find a way to fix this for good.
thanks a lot for the advise I really apreciate it im going nuts here
(in reply to Bashnbreakalot)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU2
