CA, USA Status: online
Got some early informaiton on this one. Enjoy!
Losi's 1/8-scale 8IGHT-E 4WD Buggy Race Roller combines the innovative design and technology of Losi's award-winning 8IGHT Competition Buggy Chassis with the fierce torque and speed of Losi’s 1/8-scale Xcelorin Brushless Systems.
The 8IGHT-E Race Roller is a competition buggy chassis that has been hand assembled and tuned to exact specifications. Each and every screw is installed to specific torque settings to maintain consistent construction. Additionally, every screw or bolt that secures metal-to-metal contact features thread lock to prevent backing out or loosening due to vibration. The differentials and shocks are pre-built and filled with 100% pure silicone fluid.
The 8IGHT-E Race Roller features Losi’s superior 1/8-scale Xcelorin Sensorless Brushless Power System. The fully programmable, high-output electronic speed control (ESC) can handle a 3-5-cell LiPo battery pack, and offers precise throttle and braking control. The 2100Kv brushless motor requires virtually no maintenance, while offering unmatched efficiency and speed designed for 1/8-scale racing. Additionally, the ESC offers tons of programming options, including adjustable throttle limits, selectable user profiles, and much more using the Quick Programming Card or personal pc programming software.
Once assembled, the 8IGHT-E Race Roller is given a complete inspection to ensure that it meets Team Losi Racing’s requirements for durability and performance. You can be sure that your 8IGHT-E Race Roller is ready for serious competition as soon as you open the box.
Features
Pre-installed Xcelorin 1/8-scale Brushless System with 2100Kv Sensorless motor w/5mm shaft Secure, hard-mount Xcelorin ESC with rubber shock absorbers 4mm motor mounting screws Large ESC heat sink with fan to keep damaging heat away Molded LiPo battery tray with hook and loop straps that can accommodate a 3S to 5S LiPo Newly designed body specially built for the 8IGHT-E for improved air cooling of the electronics Adjustable aluminum motor mount with rear motor support 4mm thick machined and hard anodized aluminum chassis plate Unique narrow chassis configuration for quicker handling and ground clearance Oversized shocks with threaded hard anodized shock bodies Sealed front and rear differential housings keep dirt out of the gears Zero bump steer design with adjustable Ackerman Captured hinge pins require no retaining clips Machined premium aluminum 5mm thick alloy shock towers
Product Specifications
Type:Electric Competition Buggy Race Roller Scale:1/8 Length:19.5 inches (495mm) Width:12.13 inches (308mm) Wheelbase:12.64-12.80 inches (321-325mm) Chassis:4mm Hard-Anodized Aluminum Suspension:H-Arm, Full Independent Drive Train:Offset Drive with 3 Sealed Differentials Motor or Engine:1/8 Xcelorin Sensorless Brushless Motor, 2100Kv Speed Control:1/8 Xcelorin Sensorless ESC Radio:2-Channel Radio System (sold separately) Servos:High-Torque (sold separately) Batteries:3-5-Cell LiPo Battery Pack (sold separately) Charger:Sold separately Wheel Size:17mm Hex Kit/RTR:Race Roller Shock Type:Oversized Hard-Anodized, Threaded Bodies / 4mm Shafts Body:Clear, 0.040-inch thick, Electric Buggy Racer Body Ball Bearings:Complete Needed to Complete
3-5-Cell LiPo Battery Compatible Battery Charger 2 Channel Radio System with High Torque Servos Paint for Polycarbonate Body
Joined: 6/2/2006 From: Ft Wayne, IN, USA Status: offline
That is not going to sell well, its freaking retarded expensive for a RTR brushless car.
I understand what is all invovled and that it may be less expensive than builind your own, maybe. But still its way out of reach for 99% of buyers imo.
_____________________________
E-revo - Stampede Mamba - Evader EXB - Mini T - Mini Slider - Tailwhip - MCX - AXE EZ - Blackjack 26 - Mini Rio - Turbo Vee
quote:
ORIGINAL: 04DarkShadowGT
That is not going to sell well, its freaking retarded expensive for a RTRbrushless car.
This just tells use that Losi is still in it for racing!!!!! We KNOW the HIGHroller will sell.
quote:
ORIGINAL: Ttam Says Blarg
This car is not worth that much money. I say the car cost the 200 to build and they sell it for a ridiculous price this is worth 500 max.
We are talking abotu the best competation 4wd 1/8 buggy which sells for $500 new and add a $300 brushless system and a $100 conversion kit. If you have ever driven a 8ight you will know that this is worth the money if you have it.
CA, USA Status: offline
Thats not the point. They're making whatever they are making and thats it, its a business.
For those of us who are in this hobby to enjoy it and not whine about prices, this car seems like a decent deal for what you get in terms of chassis design, performance, and electronics.
quote:
ORIGINAL: sheograth
Then don't buy it, the value of a product is subjective with regard to each individual consumer.
That said I probably won't buy it either simply because I'm not in the market for a 1/8 electric right now, but I do think its a step in the right direction for Losi.
