my first on-road
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> my first on-road
Page: [1]
Login
my first on-road - 8/29/2008 12:47:40 AM
robbio4422
Status: offline
hey guys... im new to on-road but i picked up a used tc3 last night that im going to spend a good amount of cash on...
im wonding what i might need to stay away from if im planning on racing thic car... it has a ae.15 that has a broken pull start. should i convert it to a box start? i have a box for my gt and i was told it would start the same car...
it also has a large foam bumper. what are your opinions on the rpm front bumpers?
any other suggestions would be awsome.
thanks,
-rob
for those who noticed... i did post this in the tc3 thread but i got no replies and im heading to my LHS in about an hour... plz help me out.
_____________________________
my gt brings all the girls to my yard
       Post #: 1
RE: my first on-road - 8/29/2008 5:50:46 AM
PrjctStrtFrce
Status: offline
Racing=a good suspension set-up. Get some sway bars, different shock oil, and springs. You can also get different gearing to help out with low-end or top-end.
!~!I live my life a fuel tank at a time!~!
...Fully Loaded SFGP.....Savage X 4.6...
(in reply to robbio4422)
       Post #: 2
RE: my first on-road - 8/29/2008 11:45:30 AM
GYNAIKAS
Status: offline
Suspenssion springs and tires for start...then maybe a good exhaust system. But first drive the car and find out what it needs in order to pich up the correct spring stifness and tire compound.
I simply love perfection...do something as good as you can or don't do it at all...
(in reply to PrjctStrtFrce)
       Post #: 3
RE: my first on-road - 8/29/2008 11:53:18 AM
Foxy
Status: online
You have a fair amount of work ahead of you to turn that into a race car. And even when you've hopped it up as much as is possible, it still won't be competitive with a purpose built belt driven race car, and will have cost twice as much. Are you sure you want to do this?
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to GYNAIKAS)
       Post #: 4
RE: my first on-road - 8/29/2008 4:07:13 PM
olkleaf
Status: offline
if you are going to race i would get foam tires i would change the engine and converting it to box start is a good idea. change the radio equipment (radio receiver servos) get a fail safe get an aluminum steering servo arm (at the track my plastic ones striped) buy lots of extra parts like a arms screws - prepare for the worst at the track the worst thing is when you have to go home early because you don't have the part that broke. the body is 200mm
(in reply to Foxy)
       Post #: 5
RE: my first on-road - 8/29/2008 4:20:35 PM
robbio4422
Status: offline
ok where to start will all of this feed back... i have a pic to post so ill let you all check it out...
i have a futaba 3pm 2.4g so im good there.. would it be a good idea to install a high torgue stearing servo... like i said, i have been running st's for the last 5 years
i have a few motors laying around but they are all for my trucks. i have a spare os 12tz and 12.cv-r but i dont think i can get those into an onroad... or can i?
can someone direct me to some links for any upgraded parts... all i can find is stock ae parts
Click to see fullsize image.
Click for fullsize
(in reply to olkleaf)
       Post #: 6
RE: my first on-road - 8/29/2008 4:24:38 PM
robbio4422
Status: offline
quote:
ORIGINAL: Foxy
well if anything, this will open my eyes to a new style of driving. i can always fix this car and sell it (like i do with most of my cars) and start looking for a kit on something much better to keep as my own, what would you recomend?
im willing to put as much into any of my cars as needed... if you look at my last build you can see im very much into wrenching and nothing will stop me once i have a project going.
(in reply to Foxy)
       Post #: 7
RE: my first on-road - 8/29/2008 4:30:37 PM
olkleaf
Status: offline
oh yea i forgot to tell you. if you never raced before well once you get to the track take your time around the track let the faster cars pass you don't expect to be the fastest guy there. you will get better! MAKE FRIENDS (DONT SIT AT A CORNER BY YOUR SELF- GO WHERE EVER ONE ELSE IS SITING that way the local guys will see you and talk to you) the guys there they will help you out ALOT!! ask for advice. like what tires are best for the track how should i set up my car. and just have fun!!
and if it helps you any here is the set up of my NTC3.
front toe out is at 2 degrees
rear is toe in 2 degrees
camber front and back at 2 degrees
my front shocks are in the inner hole (on the shock tower) and the outer hole (the a arm)
my rear shocks are on the middle hole (shock tower) upper hole (a arm)
my rear is 12mm off the ground and the front is at 8mm
       Post #: 8
RE: my first on-road - 8/29/2008 4:42:41 PM
robbio4422
Status: offline
is there a specific size motor that is legal or not? i know with my st's i have to run .12
       Post #: 9
RE: my first on-road - 8/29/2008 5:35:24 PM
Foxy
Status: online
Yes, .12s for 1/10th nitro racing. As for kits... When you are ready (and the TC3 is a good car to start with and just decide if the concept is for you), there are a few good cars. Since money is no object, go for the Xray NT1 or the Kyosho V-one RRR and put a racing .12 in.
       Post #: 10
RE: my first on-road - 8/29/2008 7:21:35 PM
olkleaf
Status: offline
i would check with the track first. if you want to race in ROAR or some thing like that you should get a .12 engine if you just want to race at the track i would check to see if they care. at my local track they don't car what size engine your car is or anything you can drive a pure outlaw car with out a problem like my NTC3 has an OS .18tz on it and its a killer.
(in reply to Foxy)
       Post #: 11
RE: my first on-road - 8/29/2008 8:51:49 PM
CBM Racing
Status: offline
I say put that 12tz in there and go try racing! At local tracks the tc3 is very competetive and is pretty strong for the learning curve oopsies . See what everyone else at your track is using for tires and go with what works on YOUR track. I see lots of people upgrade the diffs to steel gears, so that might be a good idea right away. Try out the setup above and go from there to fine tune it to the track. Other things you might want right away, depending on track, gearing options and spring sets. If you already have st's you probably have shock oil already so ask around at the track about prefered weight. Mostly right away it's just getting out and getting used to the car's handling and learning how to corner. Good luck and let us know how it goes!
MMmm..Piepants..
       Post #: 12
RE: my first on-road - 8/30/2008 1:56:32 PM
Cypriot Boy
Status: offline
well i thing you forgot is the differential oils, it depend on your driving of what diff oils you need.
I am glade that i am able to say that i have a prototype/concept car.... Team Magic G4+....
(in reply to CBM Racing)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
