Squares or hexes?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Squares or hexes?
Page: [1]
Login
Squares or hexes? - 8/29/2008 5:23:19 AM
Bratch96
Status: offline
Which is better, square wheel drivers like FG or hex wheel drivers like HPI Baja 5B?
I have rounded out one square on my FGMT. Has this ever happed with the baja?
_____________________________
Large Scale Hobby = Time Well Spent.
       Post #: 1
RE: Squares or hexes? - 8/29/2008 1:09:22 PM
SELWA
Status: offline
Did you round off the rim of the square?
These are Machines not toys!
(in reply to Bratch96)
       Post #: 2
RE: Squares or hexes? - 8/30/2008 8:38:31 PM
Bratch96
Status: offline
The rim.
(in reply to SELWA)
       Post #: 3
RE: Squares or hexes? - 8/30/2008 11:11:01 PM
SELWA
Status: offline
Was there a steel collar around that area? I've never seen this happen. Maybe the wheel nuts became loose?
       Post #: 4
RE: Squares or hexes? - 8/31/2008 1:17:45 AM
Bratch96
Status: offline
Yeah, it still has the steel collar, I was just wondering if hexes are better than why does fg use squares?
I don't remember if the nut came loose, I actually think that there was some friction and the heat melted it, I don't really remember.
I was just wondering if you were going to build a car ground up would you go with hexes?
(in reply to SELWA)
       Post #: 5
RE: Squares or hexes? - 8/31/2008 1:21:08 AM
SELWA
Status: offline
The square has been around on Europe's buggies for over 18 years. I'm sure if there was a problem they would have found it buy now.
       Post #: 6
RE: Squares or hexes? - 9/8/2008 3:56:01 AM
jimjeep
Status: offline
It would stand to reason that the more sides to a polygon (pentagon, hexagon, octagon, etc...) the closer it gets to actually being round and the shallower the flats are to the points. So, a square would be much less prone (about 33 percent) to stripping than a hexagon. The only reason hexes are commonly used for fastening devices is because you have less of a turn to make before getting to the next set of flats which greatly helps when working in confined areas. All my 1/5 use square drive (as all others with the exception of HPI do) and I have yet to strip a single one. Make sure the wheel nuts are always tight and if they are nylon locking replace them as soon as the nylon starts wearing out.
(in reply to SELWA)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU2
