Ignition
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine by Southeast R/C Engines, LLC.
Seller:  XYZUSA
Details:   $259.95   |  12/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Ignition
Page: [1] 2   next >   >>
Login
Ignition - 8/29/2008 6:33:23 PM
Outlw36
Status: offline
Anyone used these ignition systems? http://www.syssaaircraft.com/gas_engine_ignitions.html Ignition module died on my Evolution .26gt, looking to replace it with this system due to being way cheaper than the conversion thru Horizon.
Jim
       Post #: 1
RE: Ignition - 8/29/2008 6:41:44 PM
arobatx
Status: offline
Another option for you, Ralph Cunningham 928 635 2455, I doubt you'll find a better price on a very good ignition and Ralph is a good man to do business with. www.DLUSA.net will get you an rcexl ignition for 80 bucks, had good luck with those. The guys at CH ignitions are certainly another good choice. Give Ralph a call though...before doing anything else.
Chad
_____________________________
Chad
(in reply to Outlw36)
       Post #: 2
RE: Ignition - 8/29/2008 10:58:57 PM
MOTORMAN37
Status: offline
All of the above ignitions are from the same company. C & H, BCMA and Ralf C are all useing the same rcexl ignition as the DL. C & H puts there sticker on it, and say it is custom made for them, but it appears to be the same exact thing to me. It says RCEXL on it, but he gets $100.00 instead of the $80-90 that other guys are charging. I went with C & h because of there reputation for years.
(in reply to arobatx)
       Post #: 3
RE: Ignition - 8/29/2008 11:29:12 PM
Outlw36
Status: offline
thanks for the relies guys. I thought it appeared to be the same but wasn't sure.
(in reply to MOTORMAN37)
       Post #: 4
RE: Ignition - 8/30/2008 1:11:32 AM
RC Extreme power
Status: offline
I might be wrong but if you use one of these you will have to retime your engine, No big deal and will cost you a lot less than a new original ignition.
Milton
Importer of high performance RC gas engines
www.rcextremepower.com
       Post #: 5
RE: Ignition - 8/30/2008 1:13:51 AM
dirtybird
Status: offline
Hobbycity sells an automatic advance unit for $25.
This is the ignition used for the XYZ engines. There is a thread on XYZ engines. I don't see anyone saying the ignition is bad.
       Post #: 6
RE: Ignition - 8/30/2008 1:25:29 AM
tkg
Status: online
Just bolting on a CH RCXL or anybodys RCXL will make for an engine that is way out of time and will run poorly.
The CH conversion kit is 104.95 and included a new prop hub with a retimed keyway
FFIW
CH sells the CH RCXL ignition single for 79.95 not 100. AND the timing chip and plug wire our to our specs
TKG
To much power is just about right.
(in reply to dirtybird)
       Post #: 7
RE: Ignition - 8/30/2008 2:59:28 AM
skip1320
Status: offline
To anwser the question,yes using Todd,s rxcell works great and Todd has excellent coustomer service,good luck.
(in reply to tkg)
       Post #: 8
RE: Ignition - 9/4/2008 3:43:26 AM
captinjohn
Status: online
quote:
ORIGINAL: tkg
FFIW
QUESTION....Is there 2 versions of the RCXL ignition? One without auto advance and one with auto advance? The photo below....is this the same ignition you are selling? Thanks Capt,n
Click to see fullsize image.
Click for fullsize
I never met a engine I did not like !
(in reply to tkg)
       Post #: 9
RE: Ignition - 9/4/2008 5:53:30 AM
tkg
Status: online
quote:
ORIGINAL: captinjohn
All the RCXL ignitions are auto advance. Except for a few we did for R&D
The unit in the picture is NOT what CH sells.
TKG
(in reply to captinjohn)
       Post #: 10
RE: Ignition - 9/4/2008 3:35:55 PM
Antique
Status: offline
TKG, How is your CH version different ???
(in reply to tkg)
       Post #: 11
RE: Ignition - 9/4/2008 3:51:33 PM
tkg
Status: online
quote:
ORIGINAL: Antique
Timing curve, timing chip, plug lead.
TKG
(in reply to Antique)
       Post #: 12
RE: Ignition - 9/5/2008 4:59:50 AM
TomBat74
Status: offline
Hi There
I have been talking back and forth with Todd at SYSS since I read this thread and He is telling me that all that needs to be done to mount this on the evolution 26 is to ensure that you remove one magnet off the hub and leave the other that is timed at 28degrees from TDC on the engine hub. Then change the hall sensor on the new ignition for the one on your existing ignition ( must have something to do with the magnets???)
I have an older evolution 26gt that only has one magnet on the hub does this mean that the RCexl ignition will bolt right onto the engine that i have?
(in reply to tkg)
       Post #: 13
RE: Ignition - 9/5/2008 5:14:50 AM
Outlw36
Status: offline
I have the same version. Was hoping the ignition would've arrived today but no such luck. Oh well maybe tomorrow.
(in reply to TomBat74)
       Post #: 14
RE: Ignition - 9/5/2008 5:28:03 AM
TomBat74
Status: offline
Please keep us posted as the original ignition for this engine SUCKS! thanks,
Tom
