Dirty Birdy Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> Dirty Birdy Build Thread
Page: [1] 2 3   next >   >>
Login
Dirty Birdy Build Thread - 8/29/2008 6:56:32 PM
AllTheGoodNamesAreTaken
Status: offline
I don't think there's a build thread on the Dirdy Birdy, so I'll start one.
This is a Bridi kit from ~2001 based on the newspaper that was stuffed in the box as padding.
I will be using a new NovaRossi C60F with a tuned pipe. Southern Pro Retracts (main gear) set up as a tail dragger. Other details like servos and hardware are TBD.
The box includeds a bunch of balsa blocks, some ribs, sheeting, some sticks and a smatterning of hardware including a nylon motor mount.
The plans are well drawn and I believe one could easily scratch build this plane from the plans.
The instruction manual is more or less a novel with no pictures or illustrations.
It looks like there will be plenty of carving and sanding on the fuse to make that elegant shape. I really enjoy carving and sanding. I find it therapeutic.
Here's some starter photos...sorry about the quality, I took them with my phone.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Jeff Walker
       Post #: 1
RE: Dirty Birdy Build Thread - 8/29/2008 7:24:43 PM
acobra
Status: offline
Hi:
The Dirty Birdi is a GREAT plane, I've built 3 of them all .40 size as trikes. These may well be the best flying models I've ever had, good choice. Here are a couple of pictures of mine.
Frank[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Bild to fly NOT to crash
(in reply to AllTheGoodNamesAreTaken)
       Post #: 2
RE: Dirty Birdy Build Thread - 8/29/2008 7:26:25 PM
acobra
Status: offline
OOPS!
messed up 2 of the pictures but you get the idea
Frank
(in reply to acobra)
       Post #: 3
RE: Dirty Birdy Build Thread - 8/29/2008 7:34:46 PM
Status: offline
Very nice Dirty Birdies there acobra! I love the black one!
I'm building the .60 size.
Jeff Walker
       Post #: 4
RE: Dirty Birdy Build Thread - 8/29/2008 7:39:17 PM
petec
Status: offline
Cool.....I have a 40 size in the bones that I will finish one of these day. I built it from scratch as I was building one from a kit for I guy who used to be in our club. I had a DB 40 back in the 80's when I was a kid and couldn't resist the offer to build one again, although his and mine have foam wings since I have a foam cutter.
< Message edited by petec -- 8/29/2008 7:41:34 PM >
Team Black Magic
Pattern Junkie..Revver Brother #82..Gear Head
       Post #: 5
RE: Dirty Birdy Build Thread - 8/29/2008 7:44:03 PM
Status: offline
Here is a (stock) photo of the engine and pipe. I ordered them from plannethobby.com for $200 as a combo. I hope it lives up to is performance numbers.
High Speed Ball Bearings; Bushed Rod; True ABC Piston Sleeve Design; 8 Intake Ports; Weight 22.5 oz. Power: 2.3 H.P. at 16,500 RPM; 17mm Shaft; 1/4 x 28 Threads; Standard Glow Plug
Click for fullsize
Click for fullsize
< Message edited by AllTheGoodNamesAreTaken -- 8/29/2008 7:45:29 PM >
Jeff Walker
       Post #: 6
RE: Dirty Birdy Build Thread - 8/29/2008 11:45:44 PM
crankpin
Status: online
Time to start the Dirty Birdy. I am waiting, as I have an interest in that plane.
Crankpin
       Post #: 7
RE: Dirty Birdy Build Thread - 8/30/2008 12:16:06 AM
hrrcflyer
Status: offline
Allthegoodnamesaretaken,
YOU DA MAN!!!! I'll be following your thread with keen interest. I'm sure I'll learn quite a few things following your build. That Rossi 60 and pipe should make your plane Ballistic.
Thanks so much for doing the build thread.
Fly safe and have fun!!
David
(in reply to crankpin)
       Post #: 8
RE: Dirty Birdy Build Thread - 8/30/2008 12:35:11 AM
Status: offline
Thanks guys. Right now I'm studying the plans and instructions. Seems pretty straightforward. Right now I've got a 35% on my big building board that's just about framed up, but since I'm single, I might just start the DB on the kitchen table.
Anyone know if the Dave Brown / Southern Pro retracts will hold up to an 8lb bird?
Jeff Walker
(in reply to hrrcflyer)
       Post #: 9
RE: Dirty Birdy Build Thread - 8/30/2008 1:23:12 AM
crankpin
Status: online
Call 'em up. DB Products: 513-738-1576.
< Message edited by crankpin -- 9/9/2008 10:02:43 AM >
       Post #: 10
RE: Dirty Birdy Build Thread - 8/30/2008 2:38:29 AM
WEDJ
Status: offline
Those gears will be fine, even with 5/32 wire. We used to use them with planes of 10+ pounds.
Pilot dog FTW!
       Post #: 11
RE: Dirty Birdy Build Thread - 8/30/2008 2:53:25 AM
crankpin
Status: online
Went Flying.
< Message edited by crankpin -- 9/9/2008 10:02:04 AM >
       Post #: 12
RE: Dirty Birdy Build Thread - 8/30/2008 1:33:09 PM
Status: offline
OK, the kitchen table it is...
I got all the pieces sorted by sub assembly.
Click for fullsize
Click for fullsize
Click for fullsize
Jeff Walker
       Post #: 13
RE: Dirty Birdy Build Thread - 8/30/2008 1:42:51 PM
Status: offline
I joined the fuse halves and lined them up using a straight edge and some angle stock. I glued the doubler in place and weighed it down until it was dry.
By the way, I'm using Titebond 2.
After the glue was dry I pinned the fuse halves together and lighly sanded the halves until they were identical.
Now it's time to mark the bulkhead locations on the fuse sides.
Click for fullsize
