Saito FA-100 on World models AT-6
Tower Hobbies
Logged in as Guest
  Printable Version
Dragonus II Pro RC Helicopter - RTF
Seller:  appy2323
Details:   $475.00   |  11/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Saito FA-100 on World models AT-6
Page: [1]
Login
Saito FA-100 on World models AT-6 - 8/29/2008 9:42:20 PM
AAVN60
Status: offline
I cant figure out what i'm doing wrong here.......I had this enging running twice for about 30 seconds each. Ever since that point I cant get it started. I've changed the glow plug, made sure none of my fuel lines were clogged, and the carb line was also connected to the clunker line in the tank, I thought maybe the rubber plug at the end of the tank where the fuel lines go in was loose, but I took it apart and tightened it up and the suction/pressure is good.......I guess i'm looking for ideas or suggestions, When I turn the prop I cant even see any fuel being sucked into the line to the carb. Thanks for the help in advance!
       Post #: 1
RE: Saito FA-100 on World models AT-6 - 8/30/2008 1:45:13 AM
w8ye
Status: online
Make sure you needle valve is open at least three turns
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to AAVN60)
       Post #: 2
RE: Saito FA-100 on World models AT-6 - 8/30/2008 3:52:21 AM
ram3500-RCU
Status: offline
I have this same engine in my WM AT6. It is a fine choice. The plane flys exceptionally well with it. I have had no issues with mine. I did mount it sideways instead of inverted. If yours is inverted, you may try turning it upside down to start it. Get it all adjusted and running smoothly so minimal cranking is needed. They will flood out inverted. You need to max out the glow starter volts if inverted.
(in reply to w8ye)
       Post #: 3
RE: Saito FA-100 on World models AT-6 - 8/30/2008 5:47:14 PM
AAVN60
Status: offline
ok cool i'll try that, I did mount mine inverted.
(in reply to ram3500-RCU)
       Post #: 4
RE: Saito FA-100 on World models AT-6 - 9/2/2008 3:14:29 PM
jzrf6c
Status: offline
Here's another tip for starting inverted engines. When fueling close the needle valve if you dont have an "easy filler valve" (one that shuts off fuel flow to the carb when you insert the fuel probe). Then open the needle valve to the previous setting just before starting. It may take a few cranks to draw the fuel in but at least you wont flood the carb right off.
With the "Easy filler valve I use a small clamb (Hemostatic Forceps) to keep the fill line closed with the fill value inserted until I'm ready to start. When I take out the fill valve then fuel stsrts to flow and the engine starts without flooding.
Hope this helps.
       Post #: 5
RE: Saito FA-100 on World models AT-6 - 9/3/2008 2:48:46 AM
AAVN60
Status: offline
yeah for sure! good tip!
(in reply to jzrf6c)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU2
