Will Graupner 720 Tourqe
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Scale Boating >> Will Graupner 720 Tourqe
Page: [1]
Login
Will Graupner 720 Tourqe - 8/30/2008 3:48:29 AM
hansvonpensch
Status: offline
My questian is, will the Graupner 720 Tourqe turn a Rabosh 4 blade 3" dia, 3" pitch blade efficently. Thanks, Randy.
       Post #: 1
RE: Will Graupner 720 Tourqe - 8/31/2008 2:14:42 AM
subsinker
Status: offline
SPEED 720 BB Torque6-12 V Graupner 6372 Twin ballraced, 8-pole armature.
Special high-performance motors with integral
suppressors. Characteristic high torque at low rotational speeds, therefore ideal for use in direct-drive model boat power systems with large
propellers.
Nominal voltage 12 V
Operating voltage range 6 ... 13 V
No-load rpm 4100 min–1
No-load current drain 0,75 A
Current drain at max. efficiency 3 A
Current drain when stalled 13,5 A
Max. efficiency without gearbox 75 %
Length of case, excl. shaft 72 mm
Diameter 44,5 mm
Free shaft length 6,5 mm
Shaft diameter 5 mm
Weight 380 g
Looks like it will to me based upon the specs
Pete
_____________________________
There are two types of ships: submarines and targets
(in reply to hansvonpensch)
       Post #: 2
RE: Will Graupner 720 Tourqe - 9/1/2008 2:48:13 AM
hansvonpensch
Status: offline
In about 3 weeks I will let you know, how it turns out, thanks, Randy.
(in reply to subsinker)
       Post #: 3
RE: Will Graupner 720 Tourqe - 9/7/2008 11:35:55 PM
hansvonpensch
Status: offline
Ran it today for about 5 minutes, constant, and the motor was cold. The tug boat is about 20 pounds and has a displacement hull and was plowing the water. On full speed it started to look as if it would plow the front end under, a 36" Shelly Foss with a 12" beam. The motor preformed great.
       Post #: 4
RE: Will Graupner 720 Tourqe - 9/13/2008 1:10:36 PM
rye
Status: offline
hi
i am using these motors for my 1/16 scale landing craft could you tell me what size the bolt holes are thanks rye
http://www.rcgroups.com/forums/showthread.php?t=912756
       Post #: 5
RE: Will Graupner 720 Tourqe - 9/14/2008 7:59:37 PM
hansvonpensch
Status: offline
I remember going to Home Depot with a Grapner 700 in my hand and had to trial fit some screws off the shelf, I am 99.5% sure I use the extra screws that worked on the 700s.
(in reply to rye)
       Post #: 6
RE: Will Graupner 720 Tourqe - 9/15/2008 10:49:31 PM
Stavros Mayhem
Status: offline
you will have not problems with that set up at all I run the same motor in a Tid Tug at 40ins and that weighs in excess of 40lb runs all day without even breaking into a sweat
Stav
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU2
