Hyper 7 diff conversion
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5T - RTR
Seller:  RCJAX904
Details:   $1,300.00   |  12/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> Hyper 7 diff conversion
Page: [1]
Login
Hyper 7 diff conversion - 8/30/2008 12:42:59 PM
naynay12
Status: offline
The diff ratio to tires is around 3:1 -3:5:1(estimate) on the hyper 7. Isd there any diff conversions to change the ratio so it is more like higher something like 2:5:1 ?Such as diff conversions,or putting trugy diffs or soemthing in the hyper 7?
It is for a custom project.
       Post #: 1
RE: Hyper 7 diff conversion - 8/30/2008 12:50:21 PM
j_blaze
Status: online
yes, 10t hellfire or 11t hyper st bevel gear should do it. also hyper st 52t spur would help.
_____________________________
CASTER K8T Pro - GO 21 R-Spec JR, DX3R
Caster Zx1-R - Caster MKII 215t, Bron''s GEN2
(in reply to naynay12)
       Post #: 2
RE: Hyper 7 diff conversion - 8/30/2008 1:30:23 PM
naynay12
Status: offline
It is a custom project,fitting a gas engine 26cc in it.I need to change the ratio in it since im not using a spur gear .
By the way it works it has been done beofre so please nobody say 'that engine is to big'. I have made the chassis longer.
By bevel gears where abouts is that gear?
Also i need to change the front or rear diff gears not the centre of spur gear or clutch bell, since i dont have one.
< Message edited by naynay12 -- 8/30/2008 1:34:32 PM >
(in reply to j_blaze)
       Post #: 3
RE: Hyper 7 diff conversion - 8/30/2008 9:03:21 PM
Paradoxmaker
Status: offline
Pics please??
Jammin CR w/Go Tech .21 5 port
       Post #: 4
RE: Hyper 7 diff conversion - 8/31/2008 3:16:37 AM
naynay12
Status: offline
Here some pics,i have mounted the fuel tank that pic is about 1 week old. at the moment when i turn the diff input shaft it comes out to the tires at a ratio of about 3:3:1. I need a ratio of aroind 3:1 or even around 2:7:1.
The bevel gears is the one that connects to the diff cup in the diff right?
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by naynay12 -- 8/31/2008 3:23:28 AM >
(in reply to Paradoxmaker)
       Post #: 5
RE: Hyper 7 diff conversion - 8/31/2008 3:39:10 AM
supermod
Status: offline
lol never seen that done before
Hyper 7 Pro...21 Race...Jr x3 radio and servos,dynomite hc .086 pipe...
       Post #: 6
RE: Hyper 7 diff conversion - 8/31/2008 7:42:41 AM
SManMTB
Status: offline
Hahaha, that's crazy.
(in reply to supermod)
       Post #: 7
RE: Hyper 7 diff conversion - 8/31/2008 10:23:40 AM
naynay12
Status: offline
Lol so eveone have an answer for the tooth ratio question?
I think the gaear that is on the dog bone cup that is in the middle of the diff,well the gear on that is like 14t.The big gear on the diff is something44 teeth i think(correct me if im wromn).You divide 46 by 14 and you get about 1.3 which explains the ratio.I think if i giot a 16 tooth gears for the cone that connects to the diff and will make a ratio of around 2.8.
So i need a tooth of around 16 tooth i think?
This is jut an esti9mate it would be nice if someone came along and told me the real teeth of the gears...
Anyway sorry for the long reply though i think i will neeed a higher amount of teeth not lower like j blaze said?
(in reply to SManMTB)
       Post #: 8
RE: Hyper 7 diff conversion - 9/1/2008 10:37:47 AM
naynay12
Status: offline
Bum[...so is it possible to change the ratio?
       Post #: 9
RE: Hyper 7 diff conversion - 9/1/2008 12:21:53 PM
Dawman
Status: offline
Why are you putting this engine in ? Nitro engines are much faster .
Caster Team Member `09
AB Mechanical - for all your heating and A/C needs
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Yorkie Rescue | Humane Society |
