venom smart temp does not work with /futaba r603fs/s9452
Tower Hobbies
Logged in as Guest
  Printable Version
Hitec HS-5965 MG Brand new untouched - RTF
Seller:  kmac425
Details:   $65.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> venom smart temp does not work with /futaba r603fs/s9452
Page: [1]
Login
venom smart temp does not work with /futaba r603fs/s9452 - 8/30/2008 11:34:43 PM
dkastil
Status: offline
I just got my venom smart temp and it does not work with my futaba fasst 603fs recever and futaba digital s9452 servo . When i go threw setting the endpoints for the fail safe the servo does moove but i cant make the servo work from my transmitter ,it reads 6.5 v and the temp is like 75 but it feals like it might be triggering the fail safe ?
       Post #: 1
RE: venom smart temp does not work with /futaba r603fs/... - 8/31/2008 2:07:23 AM
systemlord
Status: offline
quote:
ORIGINAL: dkastil
Not in HRS mode it won't anyway, you have to use PPM mode for the Venom Smart Temp failsafe to work properly. I have the same receiver (603FS) as you, and it worked for me no problem.
< Message edited by systemlord -- 8/31/2008 2:10:06 AM >
_____________________________
UE SuperMaxx 1/8th Monster Truck* Custom Duratrax Vendetta Mamba 25 Motor 5400kv Impulse 3S1P 11.1v 950mAH 25C * Raptor 60
(in reply to dkastil)
       Post #: 2
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 2:13:18 AM
dkastil
Status: offline
wow that bums me out i love using hrs ,venom has to make a failsafe for hrs .
(in reply to systemlord)
       Post #: 3
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 2:26:12 AM
systemlord
Status: offline
quote:
ORIGINAL: dkastil
Unless you race or want to keep your failsafes permanent stored (set and forget), you don't need HRS. Be darn sure when using HRS you only have digital servo's, using analog servo's in HRS wil fry your analog servo's!
       Post #: 4
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 3:58:18 AM
dkastil
Status: offline
i stated that i use high end s9452 servos i like hrs to get the most i can out of my system
       Post #: 5
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 4:18:10 AM
systemlord
Status: offline
quote:
ORIGINAL: dkastil
I knew you knew, I just want to put that out there for others to see. I didn't bother enough when I got my 3PKS to carefully read every page, I ended up frying my stock throttle and braking servo. In the end I ened up buy the tiny little Venom temp monitor thats very small, I'll get some pictures of my Supermaxx when I get my new camera next Friday.
< Message edited by systemlord -- 8/31/2008 4:20:21 AM >
       Post #: 6
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 7:27:34 AM
dkastil
Status: offline
i have that one also the new smaller version that only gives min and max and current temps.
< Message edited by dkastil -- 8/31/2008 7:28:13 AM >
       Post #: 7
RE: venom smart temp does not work with /futaba r603fs... - 8/31/2008 8:21:51 AM
systemlord
Status: offline
quote:
ORIGINAL: dkastil
I love that little thing, its very accurate when compared with the pricey temp guns. I boiled water in a bowl when I first got it and it showed 212 degree F, it went un to 190°F at simmering.
< Message edited by systemlord -- 8/31/2008 8:24:53 AM >
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.953RCU2
