Receiver batteries. please help.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Receiver batteries. please help.
Page: [1]
Login
Receiver batteries. please help. - 8/31/2008 1:49:34 AM
trentiusmaximus
Status: offline
I have a JR R700 receiver. I need a compatible battery and charger. What should I get and where?
       Post #: 1
RE: Receiver batteries. please help. - 8/31/2008 2:08:37 AM
DMcQuinn
Status: online
The choice of battery is mostly a function of how large a plane and how many servos. Let us know these details.
(in reply to trentiusmaximus)
       Post #: 2
RE: Receiver batteries. please help. - 8/31/2008 2:18:00 AM
GRANT ED
Status: offline
Yep, the choices are endless. Pretty much anything will work fine. What plane is it for?
_____________________________
He who dies with the most toys wins.
(in reply to DMcQuinn)
       Post #: 3
RE: Receiver batteries. please help. - 8/31/2008 4:44:35 AM
trentiusmaximus
Status: offline
it is for a hangar 9 p-51 pts size 40. jr r700 receiver. total 5 servos. Im bidding on two 4.8v 700mah receiver type batts for like $5. Its cheap enough to just try and hope it works. What do you guys use? i would really like a higher quality battery. but i will use these for now.
(in reply to GRANT ED)
       Post #: 4
RE: Receiver batteries. please help. - 8/31/2008 12:16:20 PM
Ed Smith
Status: offline
So you have an airplane, engine and radio system and you are bidding on cheap airborne batteries and hope they work. So what if they do not? Pay the money and get good batteries.
Ed S
       Post #: 5
RE: Receiver batteries. please help. - 8/31/2008 2:43:39 PM
d_bodary
Status: offline
A new 600mah 0r 700 mah pack 4.8volts probably won't be more than 17 bucks.
NSRCA members make smooth passes
(in reply to Ed Smith)
       Post #: 6
RE: Receiver batteries. please help. - 8/31/2008 2:58:23 PM
JimO
Status: offline
I agree get a good battery pack, you never know how those on Ebay have been treated. Most likely OK, but why take a chance. Have a look at www.onlybatterypacks.com I have been using their 850 NiMh flat packs and no problems 5 packs for 25.00 plus connector and shipping. Beats Ebay and you know they are fresh.
JimO
(in reply to d_bodary)
       Post #: 7
RE: Receiver batteries. please help. - 8/31/2008 3:03:00 PM
trentiusmaximus
Status: offline
They are new in box Jr 700 mah packs for $5. Im just saying i should try them anyway since i dont have any batts right now. I am asking for brand names etc. Thanks for the input.
(in reply to JimO)
       Post #: 8
RE: Receiver batteries. please help. - 8/31/2008 3:04:07 PM
trentiusmaximus
Status: offline
and what chargers do you guys use?
       Post #: 9
RE: Receiver batteries. please help. - 8/31/2008 3:10:33 PM
KW_Counter
Status: offline
I prefer something a little larger, in the 1500 range.
It gives me more flying time between charges.
I've never had to charge at the field, always had enough for the day.
It may throw your balance off some so be prepared to make some adjustments.
Don't buy a bunch of extra packs for the future - they have a tendency do die sitting around doing nothing.
I still use the wal-wart that came with my 600 mAh battery I just do it longer.
I've bought Ebay batteries and haven't been badly burned but not real excited about them either.
I do cycle several times to form and test them before they go in the plane.
I also have a fair amount of electronic experience to make these decisions with.
Others are right, why save $15 and risk your $150 plane?
Good Luck,
KW_Counter
       Post #: 10
RE: Receiver batteries. please help. - 8/31/2008 3:13:50 PM
JimO
Status: offline
Accu-cycle Elite does it all and you can take to field and charge from you field battery
JimO
(in reply to KW_Counter)
       Post #: 11
RE: Receiver batteries. please help. - 8/31/2008 3:20:36 PM
trentiusmaximus
Status: offline
i would really not like to spend more on a battery charger than i did on the plane. im looking for something a bit more simple lol.
(in reply to JimO)
       Post #: 12
RE: Receiver batteries. please help. - 8/31/2008 3:52:33 PM
d_bodary
Status: offline
Did your airplane transmitter come with a charger? If the answer is yes it will probably charge the receiver pack also. As far as the mah that's a loaded question. for a standard servo equipped plane. such as your P-51 you should be able to get 5 or 6 flights between recharges. 10 minute flights.
       Post #: 13
RE: Receiver batteries. please help. - 8/31/2008 3:53:24 PM
JimO
Status: offline
So use the charger that came with your radio. Check your charge with a meter and you should be OK. Use an expanded scale meter that has a load switch for best results.
JimO
       Post #: 14
RE: Receiver batteries. please help. - 8/31/2008 8:49:30 PM
trentiusmaximus
Status: offline
i built the arf kit. my transmitter uses 8 AA batts.
(in reply to JimO)
