futaba 7c ...can not get my throttle to work on my parkzone trojan
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> futaba 7c ...can not get my throttle to work on my parkzone trojan
Page: [1]
Login
futaba 7c ...can not get my throttle to work on my park... - 8/31/2008 3:08:58 PM
Danoeat
Status: offline
I have all the servos set up, the ailrons, rudder and elevator all work but the throttle does not ,am i missing something? or does the esc have something to do with it?
       Post #: 1
RE: futaba 7c ...can not get my throttle to work on my... - 8/31/2008 3:20:14 PM
LesUyeda
Status: offline
Reverse the throttle channel on the Futaba. This is typical of all Futaba radios.
Les
(in reply to Danoeat)
       Post #: 2
RE: futaba 7c ...can not get my throttle to work on my... - 8/31/2008 3:29:32 PM
BuschBarber
Status: offline
I had one friend who could not get the Throttle to work below Half Throttle. It was the same with more than one ESC, so it would seem the Tx had a problem with the ESC. I have not heard if he got an answer, yet, and he may not have the 7C, but it was a name brand Tx that he used for Glow planes, as well, without incident.
(in reply to LesUyeda)
       Post #: 3
RE: futaba 7c ...can not get my throttle to work on my... - 8/31/2008 4:40:01 PM
Deadeye
Status: online
Also, try running your throttle TRIM all the way down. You might not be set right to arm the ESC.
_____________________________
Randy Rossmiller, proud husband of Terrorist Hunter www.shannenrossmiller.com
Proud & Happy customer of www.slimline.co
(in reply to BuschBarber)
       Post #: 4
RE: futaba 7c ...can not get my throttle to work on my ... - 8/31/2008 4:53:59 PM
TedMo
Status: offline
Since I'm a JR user don't know a lot about Futaba. However,yes ESC has something to do with it. Try plugging cable from ESC into throttle channel. That should do it.
       Post #: 5
RE: futaba 7c ...can not get my throttle to work on my... - 8/31/2008 5:34:47 PM
Mr. Mugen
Status: online
Now there is a pile of good advise. Try to reverse throttle channel first. If that doesn't do it then try to run your trim at it's lowest point. You may need to program your esc? Some require throttle calibration, depending on the esc.
Everything electronic runs on smoke.....if you let your smoke out, it''s dead! AMA#378033
(in reply to TedMo)
       Post #: 6
RE: futaba 7c ...can not get my throttle to work on my... - 9/1/2008 11:27:43 PM
Danoeat
Status: offline
i tried all of these things guys but still no luck
(in reply to Mr. Mugen)
       Post #: 7
RE: futaba 7c ...can not get my throttle to work on my ... - 9/2/2008 12:07:16 AM
HalH
Status: offline
Run the throttle all the way up and then back to idle. This could reset the ESC. Be sure to try it with the throttle reversed.
HANG ON TO THE PLANE !
       Post #: 8
RE: futaba 7c ...can not get my throttle to work on my... - 9/2/2008 3:49:21 AM
icando3d2
Status: offline
I just set one of these up for a newby at the field we had to reverse the throttle center the trim then start off running the throttle from idel to full tilt then back again it worked good.
Good luck
(in reply to HalH)
       Post #: 9
RE: futaba 7c ...can not get my throttle to work on my... - 9/2/2008 3:53:36 AM
[]TEX[]
Status: offline
If you have the PNP version the ESC has to be in the off position for at least a second to arm.
Do yourself a favor and READ THE MANUAL!
I don't even own the plane and I did.
< Message edited by []TEX[] -- 9/2/2008 3:59:37 AM >
JR Vibe 50 powered by O.S. | 7C FASST | Hatori Perfomance | Curtis Youngblood | Reactor X | CSM RL20 | mCX
(in reply to icando3d2)
       Post #: 10
RE: futaba 7c ...can not get my throttle to work on my... - 9/2/2008 11:32:38 PM
Danoeat
Status: offline
Thanks guys.. finally got it i had to reverse the throttle and put the trim all the way down and it worked... thanks
(in reply to []TEX[])
       Post #: 11
RE: futaba 7c ...can not get my throttle to work on my... - 9/2/2008 11:48:14 PM
[]TEX[]
Status: offline
quote:
ORIGINAL: Danoeat
Amazing....
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
