??? echo engine question
Tower Hobbies
Logged in as Guest
  Printable Version
Evolution 116GX2 - RTF
Seller:  MRDEAD
Details:   $990.00   |  12/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> ??? echo engine question
Page: [1]
Login
??? echo engine question - 8/31/2008 10:16:37 PM
cfaw10
Status: offline
I have an echo conversion that I think is a 25cc (measured bore x stroke) with a cdi ignition and an 11mm walbro carb. I'm getting 8600rpm with an APC 14x6 and 8000 with a Topflight 14x8. I know the APC puts out about 8.5 lbs of thrust at 9400 on an O.S. 91 4stroke, and I'm looking for 10 - 11 lbs from this echo. My question is what are some of your rpm and thrust readings with various props? I'd like to know if I can get this kind of thrust from this engine before I go out and buy a handfull of $15 props to experiment with.
Thanks.
       Post #: 1
RE: ??? echo engine question - 8/31/2008 10:32:02 PM
av8tor1977
Status: offline
A 15 x 8 or 16 x 6 APC prop should get you where you want to be.
AV8TOR
_____________________________
If it's not scary, it's NOWHERE NEAR powerful enough!!
(in reply to cfaw10)
       Post #: 2
RE: ??? echo engine question - 8/31/2008 10:35:28 PM
microsprint9
Status: offline
If you need more thrust i would be looking at a bigger diameter prop, even on my 21cc weedeater i was running a 16x8 (7000rpm) and a 17x6 ( 7200rpm), 14" is just too small for an engine that size especailly if you are needing more thrust.
       Post #: 3
RE: ??? echo engine question - 8/31/2008 11:14:44 PM
cfaw10
Status: offline
Thanks, guys. I'll try that this week.
Looking at putting this on a Funtana 100.
(in reply to microsprint9)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU2
