turbodremz23
TX, USA Status: offline
quote:
ORIGINAL: PAPE Do you have a pipe? and wat car is the 26cc in? Yes I have a Jetpro, and its in a KM baja quote:
ORIGINAL: Foxy I'm shocked that the stock Zen isn't enough for you. You sure your tune is all it could be? I'm sure its not the tune..and I even took it the other day to a small engine repair shop to be sure that the tune was as good as it could be. I guess I should have listed the car and mods in my first post, but here it is. Its in a KM baja, Jetpro pipe, HPI clutch with 8k rpm spring, 8mm spark plug wire, Vertigo Diff locker..Since I installed the pipe and and spark plug wire it will slightly lift the front end even with the RR Speed set gears...but me being an occasional crack head for power, I want more. Now in response to Pro5thScaleDistributors, I had thought about the 813 carb, but have heard many mixed reviews. But now with another positive suggestion towards it, would it be a good idea to combine it with either the 30.5cc kit, or the GP290 kit? I think with the power gain from both would suffice my ever growing want for more power.
