F-20 Throttle Linkage
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> F-20 Throttle Linkage
Page: [1]
Login
F-20 Throttle Linkage - 9/1/2008 2:34:45 PM
Frag
Status: offline
This is a pretty simple question for many experienced modelers - I just want some ideas for connecting this throttle cable to my Jett 50 without using a Z bend. I guess it will involve glueing some kind of linkage to the rod since its not threaded, I'm open for suggestions-
Click to see fullsize image.
Click for fullsize
< Message edited by Frag -- 9/1/2008 2:35:31 PM >
       Post #: 1
RE: F-20 Throttle Linkage - 9/1/2008 3:01:31 PM
mk1spitfire
Status: offline
whats wrong with a z bend? Is you wire to short?
Can the throttle arm come off?
You could solder a hollow shaft containing a threaded rod the other end on it. Then you use a clevis on the threaded rod.An adjustable Plastic clevis may be best as its not going to wear the hole in the throttle arm away and not cause any metal to metal noise.
(in reply to Frag)
       Post #: 2
RE: F-20 Throttle Linkage - 9/1/2008 3:13:36 PM
Cyclic Hardover
Status: offline
Use clevis with a piece of fuel tubing over it to prevent it from popping off
_____________________________
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to mk1spitfire)
       Post #: 3
RE: F-20 Throttle Linkage - 9/1/2008 3:29:56 PM
Frag
Status: offline
Thanks guys, the rod is not too short, I could use the Z bend but I want to avoid metal to metal contact and the Z bend sometimes have some slop in them. I suppose I need to find out the size of the rod and get a threaded end to fit it, then solder it on and use a plastic clevis. I was trying to use stuff I have on hand and I don't have any threaded ends this small of a diameter.
(in reply to Cyclic Hardover)
       Post #: 4
RE: F-20 Throttle Linkage - 9/1/2008 8:40:42 PM
Flyboy Dave
Status: online
....yep, solder a threaded end on it, and use a plastic connector.
FBD.
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Frag)
       Post #: 5
RE: F-20 Throttle Linkage - 9/2/2008 2:49:40 AM
Kmot
Status: online
Yup...
Click for fullsize
DRILL BABY DRILL!!!
(in reply to Flyboy Dave)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU2
