Dual rate settings
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 260 2.6m - RTF
Seller:  96918
Details:   $4,300.00   |  11/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Dual rate settings
Page: [1]
Login
Dual rate settings - 9/1/2008 3:19:31 PM
darticus
Status: offline
Is it normal not to use a rate at maximum? I usually fly with a new plane with a dual rate radio DX7 set at Rate setting 1- 70% for rudder, ailerons, elervator than going to setting 2, after getting use to it, which for me is 125%, which I set into the radio. This Is usually good but do some planes need lower settings. I'm new to this but have one small plane that is real sensitive if the ailerons are set to 125 and the slightest extra lever movement causes it to go out of control. At a lower setting it is fine but do some planes require the setting to always be set lower and can't take a higher setting. All my other planes can handle the 125 setting. Thanks Ron
_____________________________
Thanks for your help Guys, FORGEDABOUTIT! Ron
       Post #: 1
RE: Dual rate settings - 9/9/2008 7:32:18 AM
freeair
Status: offline
most models other than 3D types only need very small amounts of control to ailerons and elevators, rudder can be any setting on most sport type models. allways follow what the model specs say in terms of control throws and start from there for the first few flights until you think you may need more throws , remember too much control throw can make or really break a model. set your low rates to the required minimum and adjust your high rates to double.
(in reply to darticus)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU2
