TT GP 42 Engine Leaking and compression decline
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> TT GP 42 Engine Leaking and compression decline Page: [1]
Login
TT GP 42 Engine Leaking and compression decline - 9/1/2008 6:44:55 PM
cmoreno.rj
Status: offline
Hi everyone,
I was flying my Viper 500 with TT 42 (bearing free according to our regulations) this weekend and after some laps, it became very slow. After I check, I could see that there was some fuel leaking from the above of the engine head. I have dismounted , saw that inside the oil was black like burned oil. After I tight the screws again I opened up a little the high speed needle but it keeps leaking and losing compression after 6 laps....
Does anyone can help on that subject ? What do you recommend? Of course the easiest answer is : Buy another one !!! but I have hope that anyone can help me out !
Thanks and rgds !
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: TT GP 42 Engine Leaking and compression decline - 9/2/2008 1:29:54 AM
Duane-RCU
Status: offline
We also used these engines on our club planes. They do not like to run hot, they lose compression very fast. Do the crock pot (anti-freeze) cleaning method to get rid of any gunk that has baked on. After that, do not spend alot of time leaning it out on the ground, it will get hot fast again. If it is still fresh, it may take some time to break-in properly before it will handle max rpm. With a 10x6 MA prop, most get around 13,000 on the ground some up around 13,300 (stock muffler) If you use a 9" prop, you might get more. But this is a sport set up, and won't do big numbers. OS 8 plug works good too, 10-15% nitro max.
(in reply to cmoreno.rj)
       Post #: 2
RE: TT GP 42 Engine Leaking and compression decline - 9/2/2008 4:53:33 AM
skull1971
Status: online
the black burn on the piston means its running to lean, open the needle
_____________________________
ERIC, Revver Bro. 159, NMPRA 59i,
2009 Tri-County Barnstormer V.P., and Black Sheep Squadron #1
(in reply to Duane-RCU)
       Post #: 3
RE: TT GP 42 Engine Leaking and compression decline - 9/2/2008 6:03:55 AM
freeair
Status: online
try a new head shim plus torque the head down evenly and tight.
(in reply to skull1971)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU2
