Break in bench video
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> Break in bench video
Page: [1]
Login
Break in bench video - 9/1/2008 6:53:07 PM
supertib
Status: online
well I finally got around to taking a short video of how I use a break in bench.... the video is clips of tank #4 and #5..the motor has already been heat cycled using a heat gun, as well as initially idled to seat the bearings...Usually around tank 3 I start to push the motor a little harder, and slowly but steadily I push the motors harder and harder till eventually I am opening them right up...If you notice the motor is blowing lots of smoke...as well the prop produces a significant amount of load and wont let the motor over rev...if you try to push RPM to far the motor will reach a certain RPM then just start to sag till you let off the trigger....I have done dozens of engines using this method with excellent results, i can have a motor track ready in as little as 4 tanks of fuel.......only downside is this is deafening, i usually wear ear plugs but I forgot to bring some when I shot the video..
http://www.youtube.com/watch?v=VuP0H3Ot1lM
_____________________________
seeing is believing !
       Post #: 1
RE: Break in bench video - 9/1/2008 7:58:19 PM
Spetz
Status: offline
Nice work
That prop seems pretty small though, is it actually putting enough load on the engine?
(in reply to supertib)
       Post #: 2
RE: Break in bench video - 9/1/2008 8:04:40 PM
supertib
Status: online
quote:
ORIGINAL: Spetz
Nice work
the prop is insanely pitched..its almost like pushing a flat blade...the amount of air it pushes is insane....the load of that prop is beyond the load you would ever see in any properly geared MT or Truggy..on a 21 the motor will hit around 30 000 RPM before it will fall off pipe and push no further...the prop is short for safety reasons, but to compensate its built with a very steep pitch, this is a specially designed prop, it is not an airplane prop converted....no plane motor would ever use a prop with this pitch, its far too aggressive....
(in reply to Spetz)
       Post #: 3
RE: Break in bench video - 9/1/2008 9:51:13 PM
Over_revO
Status: offline
Seemes to work good!
Nice setup Neil.
Mike
       Post #: 4
RE: Break in bench video - 9/1/2008 10:07:33 PM
Spetz
Status: offline
What kind of prop is it then?
(in reply to Over_revO)
       Post #: 5
RE: Break in bench video - 9/1/2008 10:15:17 PM
supertib
Status: online
quote:
ORIGINAL: Spetz
its from the RD Logics break in bench !
(in reply to Spetz)
       Post #: 6
RE: Break in bench video - 9/1/2008 11:08:19 PM
Colt4g63
Status: offline
quote:
ORIGINAL: supertib
quote:
ORIGINAL: Spetz
Thats the same prop I use as I use the RD Logics bench. Nice tool to have without a doubt.
Adam Blevins, Owner & Operator of AB Mods
X-Dyno equipped
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU2
