gravediggerracing
IL, USA Status: offline
quote:
ORIGINAL: rcpowerhorse quote:
ORIGINAL: gravediggerracing quote:
ORIGINAL: adzey well Im Only 13, And Ive only Been In Nitro Now For 9 Months But... Hey man, I hope you don't drive that truck with those different sized tires. If you do, you are eventually going to destroy your transmission output assy. On a 4wd vehicle, real or RC, the front and rear tire sizes must be the same diameter or else one set of tires is going to attempt to spin faster than the other set and you can see where the issue lies with this because the front and rear outputs in the trans are locked together-on a real 4wd vehicle, the transfer case will usually explode or something in it will break. RC is no different as physics are physics. Sorry if it was off topic, but that caught my eye in the picture. the 'larger' tires aren't actully bigger they just look it because they are closer to the camera, it's all to do with the physics of perspective Sound good man.
_____________________________
Counting down the days until Savage Flux HP is released......
