Futaba 6014 heat failure (crash)
Tower Hobbies
Logged in as Guest
Users viewing this topic: 009
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Futaba 6014 heat failure (crash)
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Futaba 6014 heat failure (crash) - 9/1/2008 7:44:59 PM
summerwind
Status: offline
my biggest scare of all time was this morning and i really am glad no one got hurt. i also need to make a formal apology to anyone else who has had an issue with a Futaba 6014 2.4Ghz Rx shutting down from heat, and i can also say i now know how bad it feels.
i'm not going to bash Futaba, and i am going to keep on using all my Futaba gear, especially since i just bought the 12Z this year, but i am deeply dissapointed at losing one of my best airplanes in the learning process.
the Skybolt was in the air at the time, and after we collected all the scraps and set it in under the shade, the Rx after about 2-3 minutes cooling time, finally went from Red to Green and control of the servos was reinstated.
i guess it will also be best to send the Rx in and have it checked.
Click to see fullsize image.
Click for fullsize
< Message edited by summerwind -- 9/1/2008 8:36:52 PM >
       Post #: 1
RE: Futaba 6014 heat failure (crash) - 9/1/2008 8:38:43 PM
summerwind
Status: offline
and because i know i will be questioned about this issue, i am posting pics of how the Rx was mounted...............
Click for fullsize
Click for fullsize
(in reply to summerwind)
       Post #: 2
RE: Futaba 6014 heat failure (crash) - 9/1/2008 8:52:42 PM
Josey Wales
Status: online
Sorry to read this!
_____________________________
Joe
       Post #: 3
RE: Futaba 6014 heat failure (crash) - 9/1/2008 9:20:11 PM
Campgems
Status: online
Summerwind, I know what you felt. I lost a scratch built last week from a battery failure, it open and turned off everything airborne. This was with a 72mhz Futaba system. One of the welded tabs let loose from the battery cell. THe plane circled for several minutes, loosing about 5 ft of elevation each revolution. Its a bad feeling not having any control and the plane is still flying.
JR is making hay off this problem. The last Model Avaiation on the back cover, has a JR/Spectrum ad saying that their receiver will still work when the case starts to deform at 307 degrees. Futaba had a notice on their site and there was a thread that both got pulled down about the FUtaba heat issue. I haven't seen anything more on FUtabas site no here on RCUniverse. I'm not flying 2.4, but I'm the web master for our club and I have a page with all known (verified) issues with radios. WWW.Sloflyers.com
Sorry about the plane, and I would send in the receiver for a checkup and tell them you would like a replacement plane also.
Don
       Post #: 4
RE: Futaba 6014 heat failure (crash) - 9/2/2008 5:25:42 AM
ira d
Status: offline
Im sorry to here of your crash but im so glad that more of the truth about the Futaba
receivers are comming to light because at some point Futaba will have to step up to
the plate and correct the problem are they will loose a lot of sales.
Ira d
       Post #: 5
RE: Futaba 6014 heat failure (crash) - 9/2/2008 12:12:11 PM
summerwind
Status: offline
you know the most ironic part of this is that 2.4Ghz technology is what brought me back to modeling after a 15 year layoff.............in the past i had been shot down twice by the same guy in our club when he switched on his radio.......(yeah he's an idiot, but owned the local hobby shop too)............and had several hits in areas around our field.
with 2.4 Ghz i figure we are safe from that, but to have a radio lose communication was a pure gut wrenching event.................funny thing is, before i bought the 12Z with this fabulous 14 channel Rx, i flew the Skybolt since last summer with the 6EX 2.4.....................never an issue.
(in reply to Julez)
       Post #: 6
RE: Futaba 6014 heat failure (crash) - 9/2/2008 12:46:59 PM
skorp_jon
Status: offline
Are you sure it was heat problem ? Did you measuse heat of the receiver.
I really don't know how could receiver get so hot in the plane when you are flying.
In my pilon racer i have receiver near 80A regulator and battery and max. temperature that i have measured was 40C "104F" on the receiver.
On my large planes i have a lot of space and my receiver is not even warm.
I know they have heat problem and they should fix that. But here max. outside temperature when i fly is 30C so i think i will be ok. Until i crash
       Post #: 7
RE: Futaba 6014 heat failure (crash) - 9/2/2008 7:33:04 PM
summerwind
Status: offline
skorp,
i agree, but no matter how you cut it, i had no control of the model.
i have sent Bill Baxter a link to this thread as well as emailed Hobbico............but i think we all know that i am SOL on this and they will just try to sweep this under the rug............i haven't posted this incident on the other forums yet so as to give Bill a chance to let me know what is going to happen on this, but i won't wait a whole lot longer as i have also PM'ed Bill with regards to some Futaba analog servos that rotate to an extreme position on boot up of which he has not replied either.
i love Futaba radios, but enough is enough................there are some quirks in their system, and it's not right for modelers who are Futaba users since day one, let alone new users, to do all the Beta testing at our expense.........................scariest part is, what if someone had been injured?
(in reply to skorp_jon)
       Post #: 8
RE: Futaba 6014 heat failure (crash) - 9/2/2008 7:55:41 PM
skorp_jon
Status: offline
You are right. I have also problem with graupner (JR) 5077 servos. When i turn on the transmitter servos go to the one side and then jump back.
This is not big problem for me, because my servos don't go over limit. But may be problem in some planes when servo go over limit.
Futaba really need to fix that. I will be happy to send back my receivers to be fixed for that.
Futaba have great system, but they should improve it to be perfect system.
       Post #: 9
RE: Futaba 6014 heat failure (crash) - 9/2/2008 8:21:29 PM
summerwind
Status: offline
skorp,
the problem i had was with the little 3114's that are recommended by Great Planes for use in their Reactor Bipe...........putting two barndoors on a little servo works for normal operation and flying, but when the Rx boots up, they get Whammed!!.....stripped out 4 of them now. what adds to it is when trying to plug the ESC into the Lipo.........if you don't get it connected just right the first try, then you end up touching the connectors again, and then the poor little 3114 gets screwed in the process...................i have posted this in the Futaba mfg. board and it got lost.
< Message edited by summerwind -- 9/2/2008 8:22:23 PM >
       Post #: 10
RE: Futaba 6014 heat failure (crash) - 9/2/2008 10:17:54 PM
8178
Status: offline
I’m sorry to hear about the problem with the Futaba equipment. I’ve used their servos for more than 20 years and my 9C Super 72 mhz for a number of years with great results. I’m disappointed that Futaba has not been more aggressive with solving their 2.4 problems. To make it worse the other leading 2.4 radio manufacturer is mocking Futaba in their ads. Very sad to see this kind of stuff happen to Futaba and then they don’t do anything about it. I hope they wake up soon!
       Post #: 11
RE: Futaba 6014 heat failure (crash) - 9/3/2008 12:43:25 AM
craigteffe
Status: offline
I have to say that if more people would take heed of true issues with these recievers we would have less crashes.
I posted a problem with these and other recievers a while back and everyone wanted to blame the install or said that i was making the issue up.
If interested please thake a look in this thread and keep it alive so that more people can be warned.
http://www.rcuniverse.com/forum/m_7645681/anchors_7645681/mpage_1/key_Futaba%252Cheat/anchor/tm.htm#7645681
Read the thread and see what you guys think.
< Message edited by craigteffe -- 9/3/2008 12:46:23 AM >
Craig
(in reply to 8178)
       Post #: 12
RE: Futaba 6014 heat failure (crash) - 9/3/2008 2:44:34 AM
d_wheel
Status: offline
Have you checked to see what temp your receiver shuts down at? It appears that some cut off as low as 130 while others at 150 or higher. Was your receiver under a bubble canopy?
Later;
D.W.
Gettin'' old ain''t for sissies.
(in reply to craigteffe)
       Post #: 13
RE: Futaba 6014 heat failure (crash) - 9/3/2008 3:28:09 AM
Mr. Mugen
Status: online
quote:
ORIGINAL: craigteffe
