Wan to help ID some cox engines?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Wan to help ID some cox engines?
Page: [1]
Login
Wan to help ID some cox engines? - 9/2/2008 7:11:05 AM
sscherin
Status: offline
I found a box of old RC stuff today while helping clean my dads old garage.
I haven't seen this stuff since 1986.
I know what 2 of them are but the 2 others I'm having a little trouble with
The little one I know is a pee wee .020. It was the first engine I bought back in 1984
The other 3 we picked up at a swap meet in the mid 80's
I believe the black one on the glider pod is a Black Widow .049
I'm not sure about the large one (a medallion I think) or the black one with the white tank.
that one is odd.. the crank case is plastic or fiberglass and the spinner is spring loaded... turn the prop backwards and let go.
The prop is marked testors
close up individual shots here
Pee Wee .020
http://www.pontiacs.org/pics/projects/RC/cox/IMGP7250.JPG
Medallion?
http://www.pontiacs.org/pics/projects/RC/cox/IMGP7251.JPG
??? testors??
http://www.pontiacs.org/pics/projects/RC/cox/IMGP7252.JPG
Black Widow .049
http://www.pontiacs.org/pics/projects/RC/cox/IMGP7253.JPG
Group Shot
< Message edited by sscherin -- 9/2/2008 7:12:28 AM >
_____________________________
AMA #163334
There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance
       Post #: 1
RE: Wan to help ID some cox engines? - 9/2/2008 2:35:18 PM
fritzke
Status: offline
You got em:
Cox Black Widow .049
Testors "Rewind Start" .049, typical of the ones in all the Testors UC planes
of the 70's
Cox Medallion .099
Cox Pee Wee .020
Dave
(in reply to sscherin)
       Post #: 2
RE: Wan to help ID some cox engines? - 9/2/2008 2:38:06 PM
on pipe
Status: offline
You've got them pretty much nailed down. The one on the pod is a Black Widow, the one with the spinner is a Testors (Wen Mac), and the Medallion looks like an .09. Ross
       Post #: 3
RE: Wan to help ID some cox engines? - 9/2/2008 4:27:20 PM
sscherin
Status: offline
Great thanks!
I didn't know about the Wen Mac/Testors planes.
Do you think the .09 would fly ok on a House of Balsa FW-190?
I was going to use my OS .15 but this motor is much lighter.. I can live with no throttle.
might have to find a muffler though. Club rules and all.
AMA #163334
(in reply to on pipe)
       Post #: 4
RE: Wan to help ID some cox engines? - 9/2/2008 4:36:11 PM
planebuilder66
Status: offline
Yeah, it'll scream, my .07 norvel hauls mine stupid fast with a 7 x 3 dynathrust, just make sure you coaYeah, it'll scream, my .07 norvel hauls mine stupid fast with a 7 x 3 dynathrust, just make sure you coat the inside of the cowl with thinned out 30 minute epoxy B/C it's going to puke tons of castor all over the inside. I love my HOB FW190.t the inside of the cowl with thinned out 30 minute epoxy B/C it's going to puke tons of castor all over the inside. I love my HOB FW190.
Click to see fullsize image.
Click for fullsize
       Post #: 5
RE: Wan to help ID some cox engines? - 9/2/2008 8:01:26 PM
supagloo
Status: offline
quote:
ORIGINAL: planebuilder66
Double vision? Triple vision? Need new batteries in my glasses i think
Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
(in reply to planebuilder66)
       Post #: 6
RE: Wan to help ID some cox engines? - 9/2/2008 9:25:22 PM
gcb
Status: offline
The Tetors is the "Testors 8000". It was the last .049 engine Testors made before going belly up. It is a good running engine. Here is a pic of some. The one on the right is a "Product" engine from a RTF. It has a pot metal crankcase whereas the others use a moulded carbon plastic crankcase.
George
Click for fullsize
       Post #: 7
RE: Wan to help ID some cox engines? - 9/3/2008 1:08:27 AM
on pipe
Status: offline
George! How many engines do you have? Not only do you come up with ONE sample of an engine, but usually multiple examples for reference! You must be a bachelor or have a very understanding wife! Ross
(in reply to gcb)
       Post #: 8
RE: Wan to help ID some cox engines? - 9/3/2008 2:35:21 AM
gcb
Status: offline
Never counted them.
Very understanding wife.
George
       Post #: 9
RE: Wan to help ID some cox engines? - 10/21/2008 12:49:40 AM
JohnAV8R
Status: offline
You might find this site interesting. Shows all the Cox engines made and several proto types, ie .35
http://www.mh-aerotools.de/airfoils/cox_frameset.htm
       Post #: 10
RE: Wan to help ID some cox engines? - 10/21/2008 1:50:48 AM
Andrew
Status: offline
quote:
ORIGINAL: on pipe
I've made the exact same comment in another thread. George must have one of the premier collections of small engines in the states. I'm always impressed, as you have noted, that he has multiple engines and not just one.
andrew
< Message edited by Andrew -- 10/21/2008 1:51:11 AM >
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
       Post #: 11
RE: Wan to help ID some cox engines? - 10/21/2008 6:41:12 PM
gcb
Status: offline
As stated, I have never counted them. I would guess over a hundred but less than 200. And no, it is not a "premier" collection. Some collectors have several times that many...in just one size, plus their others.
I never intended to be a collector...fully intended to have them all in the air at some point. I guess now it would take several lifetimes.
George
(in reply to Andrew)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
