gcb
NY, USA Status: offline
jeffie8696, Make sure the pickup on the NORVEL tank is in the correct place for CL...mine was setup for RC with pickup on bottom. I had to pull out the tubing, bend it, and reinstall it in the correct place. It works fine that way. Lose the spinner. That is WAY too much weight up front. If you still want to use that external tank, glue some standoffs on the fuselage so the tank will clear the bellcrank and mount on the side of the fuselage. In that case you may also want to use an RC radial engine mount to move the engine back some. I'm guessing that you made that venturi for better fuel draw. Nice. What size prop is that? The NORVEL .061 normally likes a 6x2 or 5.7x3 APC prop. It needs to rev to maintanin venturi velocity. Perhaps not with your venturi. Of course, as someone mentioned above, switching to a Bee type engine is easier, and maintains a power range more suited to that plane. Lots of choices. Good luck whichever way you go.
