world model extra 120
Tower Hobbies
Logged in as Guest
  Printable Version
AeroWorks Yak 54 - 50cc - RTF
Seller:  jeremy henley
Details:   $2,495.00   |  11/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> world model extra 120
Page: [1]
Login
world model extra 120 - 5/21/2003 10:49:34 PM
elkiwi
Status: offline
IŽll made the first flight to my wm extra 300 120, saito 150.
I nead help about cg, throws, and prop recomendation
       Post #: 1
world model extra 120 - 5/22/2003 8:29:57 AM
LuvBipes
Status: offline
Had one w/ 100+ flights on it (RIP) powered by an OS 120 III, Great airplane. Basically the Goldberg Extra 300 rendered as an ARF by World Models.
CG and control throws per the manual. One of my all-time favorite arfs. Lands almost like a trainer and has no bad habits. You'll like it.
For a prop, start w/ an APC 16X8, though a 17X6 would work well too.
_____________________________
Keep your eyes in the skies and your future should follow.
(in reply to elkiwi)
       Post #: 2
world model extra 120 - 5/22/2003 8:48:49 AM
IMK
Status: offline
I've only started flying my WM Extra - 120 and am using the recommended control throws with 35% expo on aileron & elevator and 40% on rudder. I've got the plane balanced at 130mm from the LE.
I'm using a 120 2-stroke with an APC 16x8 and a BCM pitts muffler.
I'm happy with this set-up so far but plan on putting it through a trimming regime provided to me by the local pattern association.
I've been told by others with far more experience on this model than me that the CG can safely go back to 140mm. This combined with a bit of weight saving (e.g. moving the battery back in the fuz by cutting a hatch underneath instead of using lead in the tail, light wheels, light spinner etc) improves the 3-D qualities (although I don't think it was ever intended for this).
I've been given a warning to watch for snapping tendencies with high rate on elevator (which apparently is not a problem if you can reduce the models weight by about 6 ounces).
I'm finding it a great flying model and am impressed with the overall quality.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.258RCU2
